Uusi Daikin Altherma ERLQ-C ilman pohjapeltiä
Jumary sanoi:
Daikinilta löytyy esite, tässä yksi kuva.
Tuo on uusi Daikin Altherma VILPin ulkoyksikkö ERLQ sivut 20-21 s
http://www.daikineurope.com/docs/ECPEN12-722_P.pdf
"1. The 4-8kW range of Daikin Altherma has a specifically designed casing to avoid the risk of ice formation on the outdoor unit coil.
• The outdoor unit has a free hanging coil,ensuring no ice accumulates in the lower part of the outdoor unit. This is key to offering appropriate frost protection and has the additional advantage that no electrical bottom plate heater is required."
Isommissa laiteissa on sitten kylmäputket pohjassa ja sähkölämmitin :cool:
"2. The 11-16kW range of Daikin Altherma (ERLQ-C) has specific frost protection to avoid the risk of ice forming onthe outdoor unit coil.
• Hot gas pass: hot gaseous refrigerant coming from the compressor runs through the bottom plate to keep the base free of ice and all the drain holes open
• Sub-cool pass: before the refrigerant pipe is split by the distributor to the hairpins, the refrigerant passes through the bottom of the coil to keep this lower part free of ice"
"Only a small capacity bottom plate heater is installed (35W) on the ERLQ-C range, with smart operation logic only operating during defrost cycles. This saves around 90% of electricity consumption compared to a traditional heat pump system with a thermostatically controlled bottom plate heater."
  • ALTHERMA_Pagrind_kat 16-17.pdf
    163,7 KB · Katsottu: 529
  • #2
Vs: Uusi Daikin Altherma ERLQ-C ilman pohjapeltiä
Tässä vielä PDF
ER(L/H)Q011-016CV3 3,4 kg R410A, Hermetically sealed scroll compressor JT100G-VD (B2)
Ihan en ymmärrä miksi sitä kuumakaasua pitää sinne pohjalle laittaa, vai onko Hitachilla patentti subcool-putken käyttöön pohjalla. ::)
Kuten tuosta nähdään, niin ei siellä takana taikka sivuilla mitään ritilöitä tarvita ei edes laitteen sivulla/päädyssä. ;)
"11-16kW range outdoor unit
• Hot gas pass: hot gaseous refrigerant coming from the compressor runs through the bottom plate to keep the base free of ice and all the drain holesopen
Aika alhaalle tuo voidaan asentaa :eek:
"Unit should be installed in a way that a minimum of 10 cm free space is assured below the unit’s bottom plate at all conditions (prevent burying in snow), e.g.: heavy snowfall (if necessary construct a pedestal)."
http://server.mmc.bg/MMCpublic/CD%20DAIKIN%202012/4_Heating-Daikin_Altherma/1_LT_Split/1_Outdoor_Units/2_ERLQ-C_Large/Documents/Databooks/DB_ERLQ-CV3_EN_tcm135-169082.pdf
  • ECPEN12-722_P 7.pdf
    73,7 KB · Katsottu: 511
  • DB_ERLQ-CV3_EN_tcm135-169082 14.pdf
    236,6 KB · Katsottu: 547
Tässä vielä pienemmän Data Book
ERLQ004-008CV3 1,45-1,6 kg R410A, Hermetically sealed swing compressor 2YC36BXD#C /2YC45DXD#C
Optiona tähänkin saa "Drain pan heater kit"
http://www.soras.lt/media/ALTHERMA_PDF/ERLQ-CV3_final_tcm135-242188.pdf
