R32 DROP-IN ,R410a PHASE-OUT - Mikä muuttuu
  • Viestiketjun aloittaja Viestiketjun aloittaja scop
S
scop
Daikinin lisäksi kohta kaikki(?) muutkin pelurit apajalla .
Lanseeraukset lähinnä tähän mennessä tropiikin seudulle.
Fujitsu maailmalla pistää liitinvalinnallaan pakkaa sekaisin:
http://tropex.co.nz/Portals/571/TropexPDF/R32%20Service%20Training.pdf
Miten Daikin toimii liitinten suhteen Euroopassa?
Yksi GREE:n cooling-versio Hitachin rotary-kompuralla mulkattu R410a => R32:lle normi POE-öljyillä :
=> kuumakaasulämpötila hallinnassa
http://www.ahrinet.org/App_Content/ahri/files/RESEARCH/AREP_Final_Reports/AHRI-Low-GWP-AREP-Rpt-031.pdf
At first, we worried the high discharge temperature of R32 would affect the compressor reliability, since
it is nearly 20 ℃ higher than that of R410A according to thermodynamic calculation. Owing that capacity
of both heat exchangers are big enough, the discharge temperature of R32 has been limited. As figure 5
shows, difference of measure discharge temperature between baseline R410A and alternative R32 is
within 6℃.
Pakkaskäytös sitten jo arvuuttelun alla - siis miten kompura tahkoaa ylikuumaa öljyn kiroiksi ?
Vs: R32 DROP-IN ,R410a PHASE-OUT - Mikä muuttuu
Tässä Danfossin tekstiä ja kuvia
"• Saturated pressure: R32 has a similar pressure as R410A. This can ease the development on an R32 system based on an R410A platform.
• Critical temperature: R32 has a higher critical temperature which yields a higher COP.
• Latent heat of vaporization: The heat needed to evaporate R32 is greater than that of R410A so that the required mass flow rate per unit cooling capacity is smaller and the COP is higher.
• Isentropic exponent: This can impact the pressure ratio of the system and also the discharge temperature. So R32’s pressure ratio is a little higher than R410A.
• Volumetric cooling capacity: R32 has got a significantly higher volumetric cooling capacity than R410A, which can help to reduce the system pipe size and increase the efficiency.
• Density: R32’s density is much smaller than R410A, so the amount of charge is smaller, and since the GWP is measured per kg, the total climate impact from the refrigerant in the system is even smaller than suggested by the GWP.
From the above mentioned, R410A, R32 has a better system efficiency, and it needs a smaller refrigerant charge. The significant problem is that R32 has a high discharge temperature. Its direct consequence is the oil degradation which can cause various compressor failures like bearing seizure, low system and compressor efficiency. So the discharge temperature should be limited at an acceptable level to make sure that system and compressor could work normally. Usually is to control discharge temperature by refrigerant. Liquid injection could be a good solution for high discharge temperature directly. As shown in Figure 2 a portion of the condensed fluid is injected into scroll through an electronic injection valve, which will absorb the heat of intermediate compressed gas to vaporize. Thus the discharge temperature can be lower down effectively. And the injected mass flow rate can be easily modulated by injection valve. "
http://www.danfoss.com/BusinessAreas/RefrigerationAndAirConditioning/Articles/A+Step+Towards+More+Environmentally+Friendly+AC+-+Systems+and+Heat+Pumps.htm
Dokuja
http://www.danfoss.com/BusinessAreas/RefrigerationAndAirConditioning/Literature/RA_Documentation.htm?CatalogKey=RA-6aa56192-f7e6-4793-b7f9-4c2fa908cc23-en-TT:RA-6aa56192-f7e6-4793-b7f9-4c2fa908cc23-en-TT&DocumentType=All&Language=en&FreeText=R32&IncludeCurrent=True&IncludeArchived=False
Emmerssonin tietoutta R32 ja muut HFO kylmäaineet, esim. "System drop-in test"
http://www.emersonclimate.com/en-us/Documents/R32_and_HFOs_as_Low-GWP_Ref_for_AC.pdf
R32 ILPejä ovat esitelleet Japanissa ainakin Daikin, Mitsubishi Electric, Panasonic ja Hitachi.
http://www.coolingpost.com/world-news/panasonic-and-hitachi-add-r32-units/
ja ME +MHI loistaa poissaolollaan .
Uskalsivat julkaista scrollin suorituskykyä tarkemmin vain n. -9C:n pakkasille asti => imukaasu lämpötila karkaamassa käsistä !
Tosi pakkasilla (-17C) ollaan jo vaiti!
scop sanoi:
Olihan Electric jo mukan 3.9.3013 julkaistulla uutisella. ???
"Now Mitsubishi Electric has announced that it will introduce 11 new Z series room air conditioning models in Japan in November running on R32."
http://www.coolingpost.com/world-news/mitsi-to-launch-r32-units-in-japan/
Tässä hiukan lisää tietoa
http://techon.nikkeibp.co.jp/english/NEWS_EN/20130826/299140/
ME:n R32 kompura on nimeltään "Shinkai compressor"
http://www.mitsubishielectric.co.jp/news/2013/pdf/0822-c.pdf
http://www.mitsubishielectric.co.jp/news/2014/pdf/0122.pdf
Niinpäs näytti olevankin -Japaniin
ja lavealla tehorintamalla liikkeellä.
Ulkoyksikkö hailakan kuvan perusteella yksirivinen ja kattaa koko sivuseinämän ja kompuraosaston takaosan (voi olla kuitenkin myös vain
ennakoivaa hämäystä).
Jäljellä siis vain MHI suurista ,joka ei vielä julkaissut mitään ?
Gree hyvin ajoissa R32-serteissään Euroopassa .
https://www.ejarn.com/news.asp?ID=23261
Fujitsu myös mukana http://www.coolingpost.com/world-news/now-fujitsu-announces-r32-units/
Fujitsun R32 mallisto Australiassa
https://www.fujitsugeneral.com.au/docs/default-source/Brochures/fujitsu-lifestyle-8pp-brochure.pdf?sfvrsn=0
Esim. ASTG18KMCA/AOTG18KMCA
Antoteho lämmitys 1.05-8.30 kW
Ottoteho lämmitys 0.20-3.10 kW
Vastaavasti 9-sarjalainen ASTG09KMCA/AOTG09KMCA
Antoteho lämmitys 0.9-5.30 kW
Ottoteho lämmitys 0.25-1.60 kW
"A flare-less joint is used to prevent refrigerant leaks and comply with safety standards."
Sisäyksikön päähän ei tule enään levitettävää liitosta vaan liitos tehdään suoraan putkeen. Ulkoyksikön päähän ei muutosta. ks. sivut 41 ja 45-54.
Panasonicin juttua japaniksi
http://panasonic.jp/aircon/function/06/
X-sarjan esittely
http://panasonic.jp/aircon/lineup/14x/
elikkä laippaliitos valskaa aina !
Mahtaako moinen hätäliioittelu tulla myös Euroopan standardiin?
Jossain näkyi ielä ,että tulevaan R32 -standardin huoltopulloon vasenkätinen jengaus erottamaan R410a -pullot .
Tästä moni tykkää!
Daikinin juttua
http://www.unep.fr/bangkoktechconference/docs/IIIB-3%20Mark%20Stanga%20Daikin.pdf
http://www.area-eur.be/system/files/Documents/F04%20P6%20Daikin%20Dhont.pdf
http://www.aracihat.com/presentations/Day%20Two/Day%202%20Session%20V%20-%2002%20Tadafumi%20Mikoshi.Daikin.pdf
"Recovery bottle 48 bar, left thread"
Dupond
http://www2.dupont.com/Refrigerants/en_US/assets/downloads/201207_2197-Purdue_Barve_Cremaschi_paper.pdf
Näyttää Daikin vievän R32:ta kuin pässiä narusta.
Tuo POE-öljy hypetys yllättävää (tropiikki!) koska ilmeisesti Pohjolaan luvassa PVE-pohjainen ratkaisu.
Hyvä niin POE:lle ,koska R410a :n päässee tästä siivestämään (jos ei sitten tyystin kielletä !)
Dupond
Konversiotesti isoon mäntäkompuraan (17kW) .
Lievässä pakkasessa ( -8C) tehot suhteessa normalisoituun R410:iin sama tai lievästi heikompi mutta COPpi
puolestaan erinomainen. Nollassa erot tasoittuivat !
Yllättävästi mäntämyllyllä kuumakaasutemp. R32:lla pysyy hyvin aisoissa myös pakkasella!
Kyllä R32 liikkuu näköjään hyvin vähäisillä kitkoilla järjestelmässä (-vähän kuin HC:kin !)
scop sanoi:
Pienempi molekyylikoko, niin karkaa helpommin.
scop sanoi:
Tästä moni tykkää!
Monta muutakin "ei tykkäätä" tiedossa. Uusiksi menee mittarit, vuodonilmaisimet. Kylmäaine muuttuu tulenaraksi.
Eikä sitä lisätehoakaan varmasti ole suuresti luvassa. R410a kun oli loppujen lopuksi R32:sta R125 ryyditettynä (tulenarkuuden poistamiseksi!)
Joten mitenkäpä se R32 niin ihmeellisen poikkeavia tuloksia voisi esitelläkkään? Osa paremmista COP:sta ym. voi mennä ja meneekin laitekehityksen piikkiin.
