jule-
Onkos tietoa mikä tuo älykäs sulatus on?
Löysin aiheesta Green patentin: (Julkaisupäivä: 2007-05-31)
AN INTELLIGENT DEFROSTING CONTROL METHOD FOR AN AIR CONDITIONER
http://v3.espacenet.com/origdoc?DB=EPODOC&IDX=WO2007059710&F=0&QPN=WO2007059710
"An intelligent defrosting control method for an air conditioner is disclosed, which comprises the following steps: setting a standard air pressure value; placing a high pressure sensor on the exhaust pipe of the compressor in the air conditioner to measure the air pressure; when the pressure value measured by the high pressure sensor is lower than the standard air pressure value, said air conditioner begins to come into the defrost mode, and if not, said air conditioner continues working in previous mode."
.. ja toinen.
A HEAT PUMP SYSTEM FOR AIR CONDITIONING UNDER A LOW TEMPERATURE AND A USING METHOD THEREOF (Julkaisupäivä: 2007-05-31)
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=WO2007059709&F=0
.. ja toinen.
