"Propane (straight) has a pressure-temperature (P-T) curve that is closer to R-22. R-22 is common for house A/C systems. Propane mixed with isobutane is what most of the hydrocarbon R-12 replacements are. Note the hydrocarbon in the name indicates it is propane and other hydrocarbon-based chemicals. The isobutane helps it mimic the R-12 P-T curve.
Will straight propane work? Yes, but it has a problem getting too cold and freezing up the evap unit. Is it dangerous? Depends on what you think, the system is sealed with no air and as long as no big leak it will never get to explosive percentages in air. In an accident it could leak, but so can gas or other flammable liquids from the vehicle. Anti-freeze can burn for example when it flashes off a hot exhaust manifold.
I would make sure to at least label any propane so you do not contaminate the next guy's recovery system. Legality is up to you, it is kind of a fuzzy area.
If you charge with anything: R-12, R-134a, propane, whatever else you should always use gages and monitor pressures. I will say that propane will run a bit higher pressure than R-12 and takes about 1/3 the amount vs R-12. The attraction for propane in R-12 system is that propane will dissolve the mineral oil lube as used in R-12 systems. R-134a will not dissolve mineral oil and that is why for best conversion results you should flush out old oil and then recharge with new POE (aka "ester") oil with the R-134a.
The reason R-134a does not work so well in R-12 conversions is not the R-134a, it is due to the condensers for R-12 are not as good efficiency and that limits what the R-134a can do for cooling. Put a newer style parallel flow condenser and it takes more heat out of the hot high pressure liquid/foam/vapor mix coming out of the compressor. More heat out of the high pressure liquid results in colder evap temps due to the temp drop due to high pressure liquid to low pressure gas after the orifice/valve expansion."
Eli pikaisen nettikurssin perusteella toimii ja öljyt ovat yhteensopivat. Korkeamman paineen vuoksi propaani ilmeisesesti jäähdyttää tehokkaammin ja jäätää höyrystimen kennoa. Paloturvallisuus ei kovin hyvä mutta kaikki korvaavat aineet taitavat myös olla palavia.
Onkohan nestekaasussa jotain sellaista epäpuhtautta mikä saattaisi aiheuttaa ongelmia. Vai pitäisikö olla tarkoitukseen myytävää puhdistettua laatua. R12 rakennetusta auton ilmastointilaitteesta on kyse.
"R-414B (HOTSHOT)* is a blend of R-22, R-124 and R-142b with hydrocarbon R-600a (isobutane) added to improve mineral oil miscibility. This blend can be used to retrofit R-12 automotive air conditioning systems as well as stationary refrigeration systems. The pressure and system capacity match R-12 in 40°F to 50°F evaporators, and the discharge pressure in hot condensers is only 5 to 10 psi higher than R-12 (a benefit in automotive AC and warmer refrigeration environments). The temperature glide runs about 13°F in the evaporator. The addition of isobutane to this blend significantly improves mineral oil compatibility, particularly for high viscosity oils used in auto AC. *Hotshot is a registered trademark of ICOR "
