Sanyo SAP-KRV94EHDX outdoor unit frosting question
  • Viestiketjun aloittaja Viestiketjun aloittaja g0L
g0L
Hello,
I'm using a Sanyo SAP-KRV94EHDX for heating.
Is it a normal behavior when external unit freezes only for 1/2 or less?
At -15C:
Maybe a refrigerant amount problem?
Thank you for any advice.
Hey,
I use Sanyo SAP-KRV94EHDX for heating.
Is normal behavior when the external unit freezes to only half or less?
Maybe the amount of refrigerant is a problem?
Thanks for all the advice.
[/ QUOTE]
Thank you for your answer. Will try to do this.
Another question about sound from pipes. Pipe length is 4.5 meters (2.5m outside and 2m inside).
Is it normal sound? :)
It looks like an old 94 has been re-installed. So.. was some refrigerant added in the process ? If not it's more likely that some has leaked out.
Adding a correct amount of refrigerant is not trivial - the old stuff needs to be taken out with a special device and then exactly correct amount is put back.
