03.11.2014 22:20:00: SHELL1: ERROR: Error executing Shell data source command
Command: /bin/cat /home/talo/virtual/rossi.txt
Command output: 88.80,7.90
03.11.2014 22:30:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 88.70,7.90
03.11.2014 23:00:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 89.10,7.90
03.11.2014 23:20:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 89.40,7.90
04.11.2014 00:10:01: SHELL1: ERROR: Error executing Shell data source command
Command output: 90.00,8.00
04.11.2014 00:10:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_temp.
04.11.2014 00:10:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_humi.
04.11.2014 00:20:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 90.20,8.00
04.11.2014 00:20:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 00:50:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 90.70,8.10
04.11.2014 01:00:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 90.80,8.10
04.11.2014 01:20:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 01:30:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 02:00:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.50,8.20
04.11.2014 02:10:01: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.70,8.20
04.11.2014 02:30:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 02:40:01: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.60,8.20
04.11.2014 03:20:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.60,8.30
04.11.2014 03:20:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 03:20:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_temp.
04.11.2014 03:20:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_humi.
04.11.2014 03:40:01: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.70,8.30
04.11.2014 04:10:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 04:10:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_temp.
04.11.2014 04:10:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_humi.
04.11.2014 04:20:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 04:20:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 04:30:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 92.00,8.30
04.11.2014 04:30:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 04:30:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_temp.
04.11.2014 04:30:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_humi.
04.11.2014 04:40:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 92.20,8.30
04.11.2014 05:00:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 06:10:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.60,8.40
04.11.2014 06:20:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.70,8.40
04.11.2014 06:30:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.80,8.30
04.11.2014 06:30:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 06:30:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_temp.
04.11.2014 06:30:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_humi.
04.11.2014 06:40:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.80,8.40
04.11.2014 06:50:32: OWFS: ERROR: Error reading sensor file: /home/talo/owfs/20.AC100C000000/volt.A
04.11.2014 06:50:34: TaloLoggerThread: Received none or unknown data for command OWFS.co2.
04.11.2014 07:00:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 92.00,8.40
04.11.2014 07:00:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 07:00:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_temp.
04.11.2014 07:00:33: TaloLoggerThread: Received none or unknown data for command SHELL1.rossi_humi.
04.11.2014 07:10:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 91.90,8.40
04.11.2014 07:20:01: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 07:30:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 07:40:00: SHELL1: ERROR: Error executing Shell data source command
04.11.2014 08:30:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 92.40,8.40
04.11.2014 08:50:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 92.70,8.50
04.11.2014 09:10:00: SHELL1: ERROR: Error executing Shell data source command
Command output: 92.40,8.50
