// More information about the API (in Finnish):
https://spot-hinta.fi/
// Support Shelly script and Spot-hinta.fi API development and maintenance:
https://www.buymeacoffee.com/spothintafi
// This script can control up to four different relays:
// - Max two relays with PRICE limit only
// - Max two relays with RANK (number of cheapest hours) AND PRICE limit
// Region to use. See supported regions in Swagger documentation:
https://api.spot-hinta.fi/swagger/ui
let Region = "FI";
// Settings - Price limit - rule 1
let SETTINGS_PRICELIMIT_1 =
// User settings
RelayIsInUse: false, // True/false: If you want to use this relay or not
PriceAllowed: "30", // Price limit (in euro cents, without decimals). Use "-99" if not wanted. If price is now less than this the relay is turned ON (or OFF if inverted - see below)
AllowedDays: "1,2,3,4,5,6,7", // Execution days: 1=Monday to 7=Sunday, separated with comma.
Relay: "0", // Shelly's relay number (Value is between 0-3 depending how many relays Shelly has). Make sure this is correct!
RelayName: "OilBoiler", // Name this relay. Name is used in debug log mostly.
Inverted: false, // True/false: Set to "true" to inverted the relay logic
// Script technical fields. Do not edit!
Url: 1,
SettingsNumber: 1,
RelayStatus: true,
RelayStatusSource: "",
RelayExecuted: false,
// Settings - Price limit - rule 2
let SETTINGS_PRICELIMIT_2 =
// User settings
PriceAllowed: "20",
Relay: "0",
RelayName: "Charger",
Inverted: false,
Url: 1,
SettingsNumber: 2,
RelayStatus: true,
// Settings - Rank and price limit - rule 1
let SETTINGS_RANK_PRICE_1 =
// User settings
RelayIsInUse: true,
Rank: "5", // "Rank" limit (number of cheapest hours today)
PriceAllowed: "0",
MaxPrice: "999", // Maximum allowed price in euro cents.
AllowedDays: "1,2,3,4,5,6",
BackupHours: ["02", "03", "04", "05", "06"], // Backup hours; if API is not answering or internet connection is down.
BoosterHours: "99,99", // Relay is always ON during booster hours. Use "99,99" to disable this.
PriorityHours: ["22", "23", "00", "01", "02", "03", "04", "05", "06"], // Hours you want to prioritize. If PriceModifier: is "0" these hours always get the smallest 'rank'. Use "99,99" to disable this.
PriorityHoursRank: "5", // How many priority hours are prioritized. i.e. "3" = 3 cheapest priority hours.
PriceModifier: "-2,56", // If priority hours have lower price - such as 'night electricity' - the difference in Euro cents.
Relay: "0",
RelayName: "WaterHeater",
Inverted: false,
Url: 2,
SettingsNumber: 3,
RelayStatus: true,
// Settings - Rank and price limit - rule 2
let SETTINGS_RANK_PRICE_2 =
// User settings
RelayIsInUse: true,
Rank: "5",
PriceAllowed: "0",
MaxPrice: "999",
AllowedDays: "7",
PriorityHours: "99,99",
Relay: "0",
RelayName: "WaterHeater sunday",
Inverted: false,
Url: 2,
SettingsNumber: 4,
RelayStatus: true,
// Script - no need to modify (usually)
// Variables needed to control the execution
let currentHour = "";
let currentHourUpdated = "";
let rounds = 0;
// This is triggered by the timer (see end of the script)
function ExecuteRelayRules() {
// Counter of exeutution rounds. First round means mostly.
rounds = rounds + 1;
// Update current hour in a global variable.
UpdateCurrentHour(rounds);
// Reset relays if hour has changed
InitializeRelaysIfHourHasChanged(rounds);
// This was initialization round. Next round is the first actual processing round.
if (rounds === 1) { print("Script initialization done."); return; }
// Return if current hour is already done.
if (HasCurrentHourBeenDone() === true) {
return;
// Execute Relays which are in use and not executed yet.
ExecuteRelayRule(SETTINGS_PRICELIMIT_1);
ExecuteRelayRule(SETTINGS_PRICELIMIT_2);
ExecuteRelayRule(SETTINGS_RANK_PRICE_1);
ExecuteRelayRule(SETTINGS_RANK_PRICE_2);
// Executes HTTP GET query for a given settings
function ExecuteRelayRule(Settings) {
// Do nothing if relay is not in use or it is already executed for this hour
if (Settings.RelayIsInUse === false || Settings.RelayExecuted === true) { return; }
// Get URL
let urlToCall = BuildUrl(Settings);
// HTTP Get Request to API
print("Execute HTTP GET. Relay name: " + Settings.RelayName + " - URL: " + urlToCall);
Shelly.call("HTTP.Request", { method: "GET", url: urlToCall, timeout: 10, ssl_ca: "*" }, ProcessHttpRequestResponse, Settings);
// Process response for HTTP GET
function ProcessHttpRequestResponse(response, error_code, error_msg, Settings) {
// Process response and get status if processing was done successfully.
let response = SetRelayStatusInShellyBasedOnHttpStatus(response, error_code, error_msg, Settings);
// Update relay executed status
if (Settings.SettingsNumber === 1) { SETTINGS_PRICELIMIT_1.RelayExecuted = response; }
if (Settings.SettingsNumber === 2) { SETTINGS_PRICELIMIT_2.RelayExecuted = response; }
if (Settings.SettingsNumber === 3) { SETTINGS_RANK_PRICE_1.RelayExecuted = response; }
if (Settings.SettingsNumber === 4) { SETTINGS_RANK_PRICE_2.RelayExecuted = response; }
// Control the relays based on the result from the API call
function SetRelayStatusInShellyBasedOnHttpStatus(response, error_code, error_msg, Settings) {
// Check for network errors
if (error_code !== 0 || response === null) {
print("Network error occurred: " + error_msg);
RunBackupHourRule(Settings);
return false;
if (response.code === 200) {
SetRelayStatusInShelly(Settings, true, "api"); // Relay is turned on.
return true;
else if (response.code === 400) {
SetRelayStatusInShelly(Settings, false, "api"); // Relay is turned off.
return true;
else {
print("HTTP status code does not indicate success. HTTP status code: " + JSON.stringify(response.code));
return false;
// Change relay status in Shelly
function SetRelayStatusInShelly(Settings, newStatus, relayStatusSource) {
// Set status messages
let statusMessage = "";
if (newStatus === true && Settings.Inverted === true) { statusMessage = "Turn relay off (inverted). Relay name: " + Settings.RelayName; }
if (newStatus === false && Settings.Inverted === true) { statusMessage = "Turn relay on (inverted). Relay name: " + Settings.RelayName; }
if (newStatus === true && Settings.Inverted === false) { statusMessage = "Turn relay on. Relay name: " + Settings.RelayName; }
if (newStatus === false && Settings.Inverted === false) { statusMessage = "Turn relay off. Relay name: " + Settings.RelayName; }
// Switch behavior based on Inverted-setting
if (Settings.Inverted === true && newStatus === true) { newStatus = false; }
else if (Settings.Inverted === true && newStatus === false) { newStatus = true; }
// Don't close relay if it is already registered as closed AND source in last control is 'api'
// When closing has been done by 'backupHour', relay can be closed again.
if (Settings.RelayStatus === false && newStatus === false && Settings.RelayStatusSource === "api") {
print("Relay is already closed. Not closing again (this allows possible other script to act)");
return;
// Set relay in Shelly
print(statusMessage);
Shelly.call("Switch.Set", "{ id:" + Settings.Relay + ", on:" + JSON.stringify(newStatus) + "}", null, null);
// Save status information into settings
SetRelayStatusInSettings(Settings, newStatus, relayStatusSource);
// Set relay status for a given settings
function SetRelayStatusInSettings(Settings, newStatus, relayStatusSource) {
if (Settings.SettingsNumber === 1) { SETTINGS_PRICELIMIT_1.RelayStatus = newStatus; SETTINGS_PRICELIMIT_1.RelayStatusSource = relayStatusSource; }
if (Settings.SettingsNumber === 2) { SETTINGS_PRICELIMIT_2.RelayStatus = newStatus; SETTINGS_PRICELIMIT_2.RelayStatusSource = relayStatusSource; }
if (Settings.SettingsNumber === 3) { SETTINGS_RANK_PRICE_1.RelayStatus = newStatus; SETTINGS_RANK_PRICE_1.RelayStatusSource = relayStatusSource; }
if (Settings.SettingsNumber === 4) { SETTINGS_RANK_PRICE_2.RelayStatus = newStatus; SETTINGS_RANK_PRICE_2.RelayStatusSource = relayStatusSource; }
// This is executed if API did not respond properly. This is NOT considered as successful execution
function RunBackupHourRule(Settings) {
// Check if settings has BackupHours property
let hasBackupRules = false;
for (let property in Settings) {
if (property === "BackupHours") { hasBackupRules = true; }
// Return if not configured
if (hasBackupRules === false) { print("This setting does not have BackupHours property. Relay name: " + Settings.RelayName); return; }
// Check if current hour is listed in backup hours
let currentHourIsListed = false;
for (let i = 0; i < Settings.BackupHours.length; i++) {
if (Settings.BackupHours
=== currentHour) { currentHourIsListed = true; }
// When current hour has not been updated for some reason, it might be better to consider this as backup hour
// Comment this line, if you don't like the behavior.
if (currentHour === null || currentHour === "") { currentHourIsListed = true; }
// Set Shelly relay according if hour is backup hour.
print("Executing backup rule for relay: " + Settings.RelayName + " - Current hour: " + currentHour + " - Current hour is backup hour: " + JSON.stringify(currentHourIsListed));
SetRelayStatusInShelly(Settings, currentHourIsListed, "backupHour");
// Get the current hour and put it in global variable
function UpdateCurrentHour(rounds) {
Shelly.call("Shelly.GetStatus", "", function (res, rounds) {
if (res.sys.time !== null) {
currentHourUpdated = res.sys.time.slice(0, 2); // f.ex. "21:34"
if (rounds === 1) { currentHour = currentHourUpdated; }
else {
currentHourUpdated = ""; // Time is null if Shelly does not have connection to time server
}, rounds);
// Initialize relay statuses if hour has changed
function InitializeRelaysIfHourHasChanged(rounds) {
if (currentHour !== currentHourUpdated || rounds === 1) {
// Skip relays which are not in use - set their "RelayExecuted" state to true.
if (SETTINGS_PRICELIMIT_1.RelayIsInUse === true) { SETTINGS_PRICELIMIT_1.RelayExecuted = false } else { SETTINGS_PRICELIMIT_1.RelayExecuted = true; };
if (SETTINGS_PRICELIMIT_2.RelayIsInUse === true) { SETTINGS_PRICELIMIT_2.RelayExecuted = false } else { SETTINGS_PRICELIMIT_2.RelayExecuted = true; };
if (SETTINGS_RANK_PRICE_1.RelayIsInUse === true) { SETTINGS_RANK_PRICE_1.RelayExecuted = false } else { SETTINGS_RANK_PRICE_1.RelayExecuted = true; };
if (SETTINGS_RANK_PRICE_2.RelayIsInUse === true) { SETTINGS_RANK_PRICE_2.RelayExecuted = false } else { SETTINGS_RANK_PRICE_2.RelayExecuted = true; };
// Check if all relays are done for this hour.
function HasCurrentHourBeenDone() {
if (SETTINGS_PRICELIMIT_1.RelayExecuted === true &&
SETTINGS_PRICELIMIT_2.RelayExecuted === true &&
SETTINGS_RANK_PRICE_1.RelayExecuted === true &&
SETTINGS_RANK_PRICE_2.RelayExecuted === true) {
print("Current hour is already done.");
return true;
return false;
// Builds URL to call the API
function BuildUrl(Settings) {
// Price limit URL
if (Settings.Url === 1) {
return "https://api.spot-hinta.fi/JustNow/" + Settings.PriceAllowed + "?region=" + Region + "&allowedDays=" + Settings.AllowedDays;
// Price and Rank limit URL
if (Settings.Url === 2) {
let url = "https://api.spot-hinta.fi/JustNowRank/" + Settings.Rank + "/" + Settings.PriceAllowed;
url += "?maxPrice=" + Settings.MaxPrice;
url += "&allowedDays=" + Settings.AllowedDays;
url += "&boosterHours=" + Settings.BoosterHours;
url += "&priorityHours=" + Settings.PriorityHours;
url += "&priorityHoursRank=" + Settings.PriorityHoursRank;
url += "&priceModifier=" + Settings.PriceModifier;
url += "®ion=" + Region;
return url;
return "";
// Main timer to execute rules
Timer.set(30000, true, ExecuteRelayRules);
