The COMPRESSOR is warranted for the LIFETIME of the original purchaser and his or
her spouse, or for so long as either of them owns the home in which it was originally
installed...
Advances In New Technologies
In 1987, the company advanced the state of compressor technology with the introduction of the Trane 3-D® scroll compressor, the industry's first scroll compressor designed specifically for the commercial air conditioning market. Trane continues as the world's leading manufacturer of orbiting scroll compressors for commercial applications.
Trane 3-D® Scroll Compressor Simple Design with 70% Fewer Parts
Fewer parts than an equal capacity reciprocating compressor means significant reliability and efficiency benefits. The single orbiting scroll eliminates the need for pistons, connecting rods, wrist pins and valves. Fewer parts lead to increased reliability. Fewer moving parts, less rotating mass and less internal friction means greater efficiency than reciprocating compressors.
Patented 3-D Scroll Compliance
Trane 3-D Scroll compliance provides important reliability and efficiency benefits. 3-D compliance allows the orbiting scrolls to touch in all three dimensions, forming a completely enclosed compressor chamber which leads to increased efficiency. In addition, 3-D compliance means the orbiting scrolls only touch with enough force to create a seal so there is no wear between the scroll plates. The fixed and orbiting scrolls are made of high strength cast iron which results in less thermal distortion, less leakage, and higher efficiencies. The most outstanding feature of the scroll compressor 3-D compliance is that slugging will not cause failure. In a reciprocating compressor, however, the liquid or dirt can cause serious damage.
Low Torque Variation
The 3-D Scroll compressor has a very smooth compression cycle with torque variations that are only 30 percent of that produced by a reciprocating compressor. This means the scroll compressor imposes very little stress on the motor for greater reliability. Low torque variation means reduced noise and vibration.
