Vs: R32 kylmäaineella olevien ILPien asennusvaatimukset
ahpe sanoi:
Scanvarm maahantuomaa Green Amber R32 ilpin liitosta ei tarvi juottaa, ei ainakaan asennusohjeessa siitä ole mainintaa.
Paljon on kaikenlaisia varoitusia R32 ja muistakin esim.
https://www.scanvarm.fi/wp-content/uploads/sites/9/2018/07/K%C3%A4ytt%C3%B6-ja-asennusohje-Gree-Amber.pdf
Dear all,
Some information about R32:
In the connection between the indoor unit and the piping is inside the house a welded joint is needed.
If the joint is outside the house then you can use the flare joints as normal.
Our Nordic series (Caldo/Solo) (Comfora/Perfera) are equipped with long piping so you can be sure that they can be put thru the wall.
Flammability of R32 can be found all over You tube and as you can see it is almost impossible to put it on fire.
Daikin have been producing R32 units since 2013 commercially and we have more than 4 miljon units installet world wide.
In respect of R410A: after 2015 you need to recover the refrigerant from the unit if you open the refrigerant circuit (including connecting a hose to the service port) and replace it with some other drop in refrigerant instead.
Until 2015 the price of R410A will increase due to quotas in the world and the net installer price today of R410A is more than 100 Euro / kg in purchase. This price will continue to grow and I expect the R410A price to be close to 5-600 Euro/kg before 2025.
Personally I would go for R32 since I have absolutely no knowlegde how my R410A compressor will react to the ne drop in refrigerant if needed service in the future. Also how does it react with the different types of oils used by the heat pump producers ?
R32 is just in the beginning if it´s evolution and the units will get better and better with the time but already now the first generations of R32 units are performing better than the R410A units that heve been evolving for around 20 years.
Expect the biggest evolution coming form heat exchanger designs as well as from the compressors.
Many best regards
Daikin
