Vs: Raspberry pi ja 1-wire
Kuinka tämän saisi lukemaan talologgerin sqlite-tietokantaa? Tietokannan nimi SQLITEDB:NAME = /home/talo/data/talo.db
apophis sanoi:Perl skripti graafin piirtoon
Tarvitaan muutama kirjasto ja gnuplot
$ sudo apt-get install libcgi-pm-perl
$ sudo apt-get install libdbi-perl
$ sudo apt-get install gnuplot
Ja itse skripti tehdään /usr/lib/cgi-bin hakemistoon
sudo pico /usr/lib/cgi-bin/img.pl
#!/usr/bin/perl -w
use strict;
use CGI;
use DBI;
use POSIX;
use Time::Local;
use Time:iece;
use Time::Seconds;
# Common constants for plots
my $tic_day = " %H";
my $plot_temps = 'using 1:3 title "Huone" with lines';
my $res_file = "/dev/shm/res" . floor(rand(1000)) . ".txt";
my $sql_res = "";
sub mysql_get_select($);
sub mysql_select($$);
sub render_temps_day($);
my $cgi = new CGI;
my $cgi_date = $cgi->param('date') || `date +%Y-%m-%d|tr -d "\n"`;
my $img_w = $cgi->param('width') || "640";
my $img_h = $cgi->param('height') || "480";
print "Content-type: image/png\n\n";
my $select = mysql_get_select($cgi_date);
mysql_select($select, $res_file);
render_temps_day($cgi_date);
unlink ($res_file);
exit;
my $cgi_date = $_[0];
my $select = "SELECT * FROM ";
$select .= "lampotilat ";
$select .= "WHERE DATE(aika)=DATE(\"$cgi_date\") ";
$select .= "ORDER BY aika ASC";
return $select
my $select = $_[0];
my $file = $_[1];
my $res = -1;
eval {
my $dbh = DBI->connect ("dbi:mysql:dbname=talo", "root", "root", { RaiseError => 1 },);
my $sth = $dbh->prepare ($select);
$sth->execute();
open (FILE, ">$file");
my @row;
while (@row = $sth->fetchrow_array ())
print FILE "$row[0] $row[1]\n";
close (FILE);
$sth->finish ();
$dbh->disconnect ();
$res = 0;
return $res;
sub render_temps_day($) {
open(G, "|gnuplot") or die "gnuplot failed";
print G <<EOF1;
set autoscale
set xtics 3600
set ytics auto
set title "L\344mp\366tilamittaukset $cgi_date"
set xlabel "Aika"
set ylabel "L\344mp\366tila (C)"
set terminal png medium size $img_w,$img_h
set output
set key left top
set grid
set timefmt "%Y-%m-%d %H:%M:%S"
set xdata time
set format x "$tic_day"
set xrange ["$cgi_date 00:00":"$cgi_date 24:00"]
set yrange [0:30]
plot "$res_file" $plot_temps
EOF1
close (G);
$ sudo chmod a+x /usr/lib/cgi-bin/img.pl
Syntaksin voi tarkistaa
$ perl -wc /usr/lib/cgi-bin/img.pl
Ja kun skripti on valmis, niin koko systeemi pitäisi olla testattavissa. Eli mene osoitteeseen http://koneen_ip/cgi-bin/img.pl ja selaimeen pitäisi ilmestyä kuvaaja! Onnittelut, jos pääsit tähän asti![]()
