Halusin katsoa energiankulutuksen ulkolämpötilan kanssa, olipa yllättävän vaikeaa. Tuollaisella energy-custom-graph kortilla onnistui.
Koodi:
type: custom:energy-custom-graph-card
series:
  - chart_type: line
    stat_type: mean
    y_axis: right
    color: red
    statistic_id: sensor.ute
  - statistic_id: sensor.energy_total
    stat_type: change
    chart_type: bar
grid_options:
  columns: full
  rows: 6
title: Energiförbrukning vs utetemperatur
timespan:
  mode: energy
y_axes:
  - id: left
    unit: kWh
  - id: right
    unit: °C
Footeriin kun tekee card_mod päivämäärävalitsimen kuten Energy-sivulla niin voi valita mitä periodia tarkastelee
Koodi:
type: energy-date-selection
card_mod:
  style:
    hui-energy-period-selector$:
      ha-date-range-picker$:
        date-range-picker$: |
          /* Forces the popup to open upwards */
          .daterangepicker {
            top: auto !important;
            bottom: 50px !important; /* Pushes it above the floating bar */
            margin-top: 0 !important;
            transform-origin: bottom left !important;
          /* Flip the popup arrow (optional, cosmetic) */
          .daterangepicker:before {
            border-top: 7px solid #ccc !important;
            border-bottom: none !important;
            bottom: -7px !important;
          .daterangepicker:after {
            border-top: 6px solid #fff !important;
            bottom: -6px !important;
      ha-card {
        /* Fixed position at the bottom */
        position: fixed !important;
        bottom: 30px !important;
        /* Horizontal centering (Stable method) */
        left: var(--mdc-drawer-width, 0px) !important;
        right: 0 !important;
        margin-left: auto !important;
        margin-right: auto !important;
        /* Styling / Dimensions */
        width: fit-content !important;
        min-width: 450px !important;
        height: 58px !important;
        padding: 0 40px !important;
        z-index: 9000 !important;
        background: rgba(25, 25, 25, 0.95) !important;
        backdrop-filter: blur(15px);
        box-shadow: 0px 10px 40px rgba(0,0,0,0.8) !important;
        border-radius: 30px !important;
        border: 1px solid rgba(255, 255, 255, 0.15) !important;
        display: flex !important;
        align-items: center !important;
        justify-content: center !important;
      .card-content {
        padding: 0 !important;
        width: 100% !important;
        justify-content: space-between !important;
      /* Hides the host element in the grid layout */
      :host {
        position: absolute !important;
        width: 0 !important;
        height: 0 !important;
(varastettu internetistä tämäkin, ei mun tekemä)
Tuli lisättyä ESP32-pohjainen eINK näyttö omaan HA-systeemiin näyttäämään sähkön hintaa (poikkeamana päivän keskihinnasta), paneelien tuottoa, sääennustetta ja lämpötiloja. Puppet add-on ottaa Lovelacen sivusta kuvan joka sitten siirretään näytölle. Kuvien mustavalkoistamisessa oli jonkin verran askartelua.
Minulla on alkanut HA energianäyttö esittämään p1 homewizardin myydyn tuotannon tiedot tuplana siirtoyhtiön raportointiin verrattuna.
Ajatuksia?
Aloin tekemään muutoksia infraan ja käsittelemään dataa HA ulkopuolella ja vain käyttämään sitä sensorien kokoelmana ja dashboard alustana.
itselle node-red ja n8n tarjoavat laajemmat mahdollisuudet käsitellä tietoja. Käytännössä HA sensorille tarjotaan vain json rakenne ja HA esittää sen. Tästä ensimmäisiä esimerkkejä 12kk rullaava pösätaulu mikä päivittyy joka yö klo 02 ja kuluvan kuukauden seuranta. Projekti jatkuu vielä että huomioidaan erityyppiset sopimukset eri jaksoilla taulussa siten että osaa myös laskea oikein.
Näitä en saanut tehtyä HA omilla työkaluilla.
Edit: selvennykseksi että AI (Claude Code Opus 4.6) on vahvasti mukana apuna tekemisessä
Taulu käyttää kulutustietona Shelly Pro 3EM tuottamaa dataa, johon tehty pieni kalibrointi korjaus että vastaa datahubin tietoja. Carunan mittari näet driftannut mittausta ylöspäin
Nyt olisi tarkoitus pikkuhiljaa edistää HA projektia. Kumpi on fiksumpi hankkia: Rasberry PI vai pieni minitietokone? Rasberryssäkin taitaa olla monta eri versiota.
Tarkoitus olisi:
- Yhdistää eri hallintasovelluksia ja hallita niitä HA:n kautta jos mahdollista (mm. Myuplink, MELCloud, Yale, Pjeid, Shelly jne.)
- Kerätä dataa exceliin (pääsääntöisesti Shellyistä ja MyUplinkistä)
Tarkoitus olisi:
Minitietokone ja virtualisoituna (konteissa tai omalla käyttiksellä), jotta voi ajaa rinnalla myös muuta. Jos päädyt Raspberryyn, niin sitten ulkoisella SSD levyllä, koska muistikortit hajoaa nopeammin.
Taitaa olla halvin ratkaisu ostaa raspberry, onkohan väliä mikä version ottaa. Halvin olisi Raspberry Pi 3 model B+ toki RAM:a 1gt. Miten suurtaa osaa tuo ram näyttelee. SSD löytyy jo, kerää pölyä (Hyvä jos saisi käyttöön). Tarkoitus olisi saada vaan homma käyntiin ja katsoa miten haastavaa tuo HA:n maailma on.
Edit: tuolla sivuillahan ne minimivaatimukset lukeekin.
Raapien hinnat ovat karanneet käsistä
Moneen vaativaankin kotiautomaatioprojektiin tosin riittäisi jopa Pi Zero, jollaisen järjestelmän kokonaishinta oheiskamppeineen nyt jää pitkälti alle satasen, vaikka hankkisi pienen SSD:n tai jatkuvaan kirjoittamiseen tarkoitetun teollisuus mikro-sd:n sekä USB-hubin ja siihen sopivan USB-ethernet-adapterin.
Kyllähän useimmat asiat saa toimimaan, mutta käytettävyys on sitten mitä on. Resurssit loppuu hyvin nopeesti ja lagaaminen alkaa.
Noin vuosi sitten koetin ajaa Hassiota Rpi4 alustalla mutta aika nopeesti tuli mitta täyteen .historiaa ja monet muut tän kaltaiset oli täysin käyttökelvottomia. Ja enkä ollut asentanut ensimmäistäkään addonia, eiku appia. Kaikki lisäpalvelut pyörii kontissa toisella koneella.
Dasboardin kanssa oli tekemistä kun käppyrät eivät piirtyneet jne
Mulla IoT alustaan kytketty yli 450 laitetta ja entityjä on tuosta 10x määrä.
Erillisillä Influxdb ja PostgreSQL kannoissa on yli 15M riviä sensori dataa vuodesta 2022 lähtien.
Tehoa i5@7500T ottaa n.12-14W, kun raspi 4 m.2 SSD lätyllä 8-10W
Ei kai ohjaustietokoneella tietokantoja tarvitse tai edes kuulukaan pyörittää? Itse tulen hyvin toimeen STM32MP2-pohjaisella ratkaisulla. Ihan mielenkiinnosta, mihin omakotitalossa tarvitsee tuollaisen määrän IoT-laitteita?
Kannat ovat eri koneella. Itsellä kotiautomaatioon kytketty 3 eri tietokonetta + NAS. Vikatilanteissa 2h kuluessa järjestelmä siirtyy ”tyhmään” passiviohjaukseen.
IoT laitteita on jokaisessa tilassa esim seuraamaan lämpötilaa ja kosteutta, ikkunoiden ja ovien tilaa, ohjattavia valoja on joitain kymmeniä, valokytkimiä muutama, energiamittaus lähes joka laitteelle, älylliset termostaatit, palovaroittimet, verhoja, robo imurit ja kaikkea muuta. Jonossa varmaan 100 laitteen edestä releitä, sekä sensoreita mitä pitäisi asentaa, eli kohteita löytyy
Tarpeellinen sensoridata on hyväksi kun kehitän generatiiviseen tekoälyyn pohjautuvaa kiinteistön ohjausta. Sensoridatan perusteella luodaan ohjaustilat ja tarvittaessa muutetaan kun havaitaan poikkeamia kiinteistön tilassa.
Itsellä HA toimii oikeastaan vain kahteen-kolmeen asiaan, kerää laitteet ja tarjoaa niiden sensorit, Dashboardin hallintaan ja statustietoon, sekä vie tilatiedot tietokantoihin.
Kaikki äly ja automaatio tapahtuu HA:n ulkopuolella.
Automaatioista vastaavat n8n ja node-red sen mukaan kummalle alustalle se on luontevampaa.
Muistin tuo 1GB voi olla aika niukka. Minimivaatimuksista on keskustelua, ilmeisesti 2 Gb voisi olla parempi.
Itsellä on Rpi5 ja 8GB muistia josta näyttää normisti olevan käytössä sellaiset 1.8 Gb. Toki taustalla pyörii useampi Add-on
Millainen verkkoratkaisu sinulla on näille? Ei taida nuo kaikki mennä yhteen IP avaruuteen?
Kaikki ei ole IP:n vaativia laitteita. Niiden lisäksi löytyy Bluetooth, zigbee ja ZWave laitteita.
Verkko on Ubiquiti UniFin laitteilla toteutettu.
12 verkkolaittetta ja UNAS
IoT verkko on /23 eli 512 osoitetta, IP laitteita verkossa ei ole kuin n.200
No nyt on käyty hankkimassa tavaraa home assistantiin. Päädyin nyt Raspberry pi 4 b (4 gt), siihen mukaan 32 gt muistikortti. Ajatuksena oli ottaa starttipaketti ja kokeilla että onnistuuko tuommoinen minulta, eli ei varmasti paras vaihtoehto. Myyjän mukaan SSD kovoa tuohon ei saisi kiinni.
Laitteita sain eilen lisättyä helposti, Yale doormania en lähtenyt vielä lisäämään kun en saanut ykkösellä toimimaan. Lähes kaikki shellyt löysi, uupumaan jäi BLU motion sensor ja vanhemman mallinen H&T sensori (toki ne eivät ole niin tärkeitä)
Emaxin älypolttimoita ei löytänyt, eikä plejd himmentimiä. Pitääpä yrittää selvitellä ne seuraavaksi.
Tarvitset BTgatewayn, Shelly gen2+ malleista löytyy passiivi BTproxy.
Sen saa aktivoitua HA laitenäkymästä,
Passiivi BTproxy kuuntelee BLE viestejä ja välittää ne HA, mutta ei pysty ohjaamaan laitetta esim.Yale lukko
Tuo puuttuva H&T anturi oli ilmestynyt yön aikana listaan. Enään tuo shellyn liiketunnistin puuttuu. Plejd himmentimiin löytyi integraatio HACS:n kautta. Enään pitää ratkaista tuo Emaxin älyvalot. Niissä taitaa olla tuki Alexan integraatioon tai google avustajaan. Käsitääkseni Alexan saa homeassistantiin cloudin kautta.
Emax on luultavasti Tuya? Niiden (Tuya) integroitavuus ei ole parasta a-luokkaa ja oma suositukseni on välttää niitä viimeiseen asti
Ne on niitä juuri ja ei varmasti ole A-luokkaa kun ei ollut hinnallakaan pilattu. Pitää katsoa mitä niiden kanssa tekisi...
Edit: Plejd integraatio laittanut nyt pari kertaa itse valot päälle ja sain nyt yalen liitettyä. Ainakin lukon saa avattua HA:n kautta ja näkee onko lukossa vai ei.
Toistaiseksi toiminut ihan ok, yhden lampun oli pudottanut pois automaatiosta. Toki valon sovelluskin oli pudottanut lampun, eli polttimossa vikaa. Ehkä korjaantui kun vaihdoin polttimon. Pikkuhiljaa pitää noita polttimoita vaihtaa johonkin toiseen. Yksi vaihtoehto laittaa "normaalit" polttimot ja säätää shellyllä esim. syttymiset. Toki mukavaa on ollut himennys,valolämpötila ja joskus myös rgb-ominaisuus.
Ja sitten yleisesti: Onko fiksuinta ottaa sovelluksen automaatiot pois ja tehdä Automaatiot ainoastaan HA:n kautta?
Saako jostain muutettu miten useasti HA kirjaa tietoa. Esim. minulla on lämpötila-/kosteusantureita ja osassa riittäisi että kirjaa tiedon esim. tunnin välein. En niillä toistaiseksi ohjaa mitään.
Yritin kahlata HA:ta läpi mutta en semmoista löytänyt, voi olla käyttäjävirhekkin. Sen verran vähän kilometrejä tuon kanssa takana.
useimmiten se on sensori mikä lähettää tiedot ja HA vain kirjaa ne.
Itsellä on n.130M datapistettä historiassa vuodesta 2022 lähtien. Osa datapisteistä on tiivistetty että energia/teholukemista on vain 15min keskiarvo
Ja HA tiivistää ne tiedot oliko se nyt oletuksena 30 päivän jälkeen. Näkee kuvaajista niin että käyrä on vähän vaisumpi jos on yli 30 päivää vanhempi
Jos zoomaa sisään vanhemmilla päivämäärillä on tuo käyrä hitusen kulmikkaampi, mutta muuten tuota ei huomaa.
Taisit tarkoittaa ihan ulkoista ssd kovoa joka liitetään esim. usb3 porttiin? Mietin vain kun myyjä sanoi ettei SSd:tä saisi suoraan tuohon Raspberry 4:seen liitettyä mutta taisi käsittää että puhun kammasta. Sen taitaa saada lisäosalla liitettyä. Ajatuksena kuitenkin itselläni juuri käyttää tuota usb-porttiin liitettävää. Toki pitää joku pienempi hankkia kun ei ole järkeä laittaa tuota 1t:sta siihen kiinni kun huomannut että kuinka vähän se muistia vaatii.
Tarkoitin USB-adapterilla liitettyä SSD-levyä, eli joko tavallista 2,5” SATA-SSD:tä tai M.2-levyä erillisessä USB-kotelossa/adapterissa. Raspberry Pi 4 tukee molempia, pienin varauksin. Netistä löytyy toimivat ratkaisut.
Eli käytännössä vaihtoehdot ovat:
2,5” SATA SSD + USB–SATA adapteri/kotelo → yleensä halvin ja varma ratkaisu.
M.2 SATA SSD + USB-kotelo → pienempi fyysinen koko.
M.2 NVMe SSD + USB-kotelo → nopein vaihtoehto, mutta Raspberry Pi 4:n USB3 nopeus rajoittaa hyötyä.
Kiitos täsmennyksestä, kyllä se taitaa tuo ensimmäinen vaihtoehto olla. Pitää vähän tutkia että minkä SATA SSD:n siihen hankkisi, iso tilavuudeltahan sen ei tarvitse olla.
Ohessa oma esimerkki taustalla olevan mini-PC:n backup-puskuri-SSD:stä USB-adaptereineen. SSD-diskin ja adapterin yhteishinta on ollut jotakin 50 euron vaiheilla (muutaman vuoden ikäinen kombo, jota ei hankittu yhdellä kertaa, vaan kasattiin ylijäämäosista).
    195,3 KB · Lukukerrat: 84
Mä en ymmärrä miksei `utility_meter` toimi päivitttäisen kustannuksen laskemiseen? Hetkellinen kustannus on ok eli osaaks kukaa sanoa mitä teen väärin? Liitteenä esimerkkikuva...
PS. Mulla on myös kuukausittainen, mutta sekä päivittäinen että kuukausittaisen arvo ei ole muuttunu 0:sta mihinkää.
YAML:
template:
  - sensor:
      # Hetkellinen kustannus (€/h)
      - name: "Uima-allas kustannus nyt"
        unique_id: uima_allas_kustannus_nyt
        unit_of_measurement: "€/h"
        state_class: measurement
        state: >
          {% set power = states('sensor.uima_allas_teho') | float(0) / 1000 %}
          {% set price = states('sensor.nordpool_kwh_fi_eur_3_10_0255') | float(0) %}
          {{ (power * price / 100) | round(6) }}
YAML:
sensor:
  # Kustannus (€)
  - platform: integration
    source: sensor.uima_allas_kustannus_nyt
    name: "Uima-allas kustannus (€)"
    method: left
    unit_time: h
YAML:
utility_meter:
  uima_allas_kustannus_paiva:
    unique_id: uima_allas_kustannus_paiva
    name: "Uima-allas kustannus päivä"
    cycle: daily
    96,7 KB · Lukukerrat: 53
Kiinnostelisi tutustua näihin tekoäly avustajiin, jotka integroituvat HA:n kanssa. Ainakin claude codelle oli useitakin eri addoneja/integraatioita, mutta taitavat kaikki vaatia maksullisen version claudesta ja ainakaan aluksi en halua maksaa mitään? Onkohan Opencodelle vastaavia ? Tarkoitus olisi siis sellaiselle, joka voi tarkastaa ja korjata esim. automaatioita jne. Kehitellä uusia ideoiden avulla.
Oletteko käyttäneet mitä integraatiota netin nopeuden seurantaan? Itselläni epäillys että netissä jotain vikaa. Minulla speedtest integraatio, antaa ihan ihme arvoja. Koneen sovelluksella antaa "normaaleja" arvoja kun käyttää yhteytenä telian tukipistettä. Speedtestintegraatiossa ei ole valittavissa telian tukipistettä.
Laitetaan tänne myös sama info kuin io-techiin:
Huh huh.. Kyllä on ollut hienot pari päivää AI koodauksen kanssa. Ostin parinkympin Openai Plus 1kk setin ja nyt päivitellyt home assistantin juttuja.
Eli rajoituksia on silti ollut ja olen ns. joutunut käyttämään gpt-5.3-codex high modelia. Monet ns. paremmista ei olleet jostain syystä tuettuja.
Ei siinä mitään tämä on ollut omaan käyttöön ihan riittävä ja enemmänkin. Olen poistanut paljon "ongelmia" jne. systeemistä. Lisäksi olen optimoinut varmaan kaikki tärkeät automaatiot ja samalla tietty poistanut mahdollisia ongelmia. AI on luonut minulle uusia käytännöllisiä automaatiota, mitä en olisi ikimaailmassa pystynyt itse tekemään. Kaikki tämä parissa päivässä ja missään vaiheessa ei ole tokenit loppuneet. 5h tokenit olivat "pahimmassa" tapauksessa jossain 20% tienoilla. Weeklyt jossain 60% paikkeilla. Ja nyt periaatteessa kaikki on jo tehty. Yritän nyt kovasti miettiä mihin loput kk tokenit voisi käyttää. 🤓😆
Kyseessä https://github.com/simon-binks/codexcode addon, jota en periaatteessa suosittele, koska päivitykset eivät ole ajantasalla ja codex tuki loppuu n. viikon päästä. Eli jos päivityksiä ei tule, niin varmaan loppuu toiminta.
