Data Points
Data Points
Here, you can find the list of features available in our IoT API. The features are divided in the following groups: Device, Electrical energy system (ESS), Floor heating (FHT), Gateway, Heating, Point of common coupling (PCC), Photovoltaic, Thermostatic radiator valve (TRV), Ventilation
You can find the feature name, a description and whether the feature is available in the Basic or the Advanced plan. Use the search field to quickly find what you are looking for. Note that the features that are available for your device varies based on your device type and the controller installed.
Device
DevPortalEuDataActRead
device.actorSensorTest
Shows the status of the actor and sensor test. Provides command to activate it.
device.brand
Shows the member ID of the device in a cascade.
device.commissioning.information
Shows commissioning information.
device.commissioning.state
Shows the current state of the commissioning process.
device.configuration.houseLocation
Shows object location.
device.configuration.measurementWeight
Shows the sensor's relative importance weight during computation of the room's state. Provides a command to set it.
device.demand.external
Shows the current demand status of the device by an external influence.
device.etn
Shows the electronic traceability number of the system.
device.heatingCircuitId
Shows the ID of the heating circuit to which the device is connected. Provides commands to assign and unassign them.
device.hmi
Shows the installed HMI type with the device.
device.identification
Shows the request for the device identification status.
device.information
Shows the device manufacturer and model.
device.lock.external
Shows the current lock status of the device by an external influence.
device.lock.malfunction
Shows the current lock status of the device by a malfunction.
device.maintenance
Shows the 'Maintenance' mode state for the device. Provides a command to reset it.
device.messages.errors.counter.d6
Shows the number of D6 errors.
device.messages.info.raw
Shows the active info messages of the controller.
device.messages.logbook
Shows the at max five most recent logbook entries of the controller.
device.messages.service.raw
Shows the active service messages of the controller.
device.messages.status.raw
Shows the active status messages of the controller.
SRC
device.name
Shows the device name set by user.
device.offPeakSignal
Shows the device off-peak signal state.
device.offPeakSignal.active
Shows whether offPeak is active or not.
device.offPeakSignal.configuration
Shows whether a offPeak is used or not and provides command to de-/activate it.
device.parameterIdentification.version
Shows information about parameter identification version.
SRC, DevPortalEuDataActRead
device.power.battery
Shows battery information.
device.power.consumption.limitation
Shows the configuration of consumption limitation.
device.power.statusReport.consumption
Shows the values of consumption limitation.
device.power.statusReport.production
Shows the values of production limitation.
DevPortalHeatingRead, Heating, DevPortalEuDataActRead
device.productIdentification
Shows the device identification data.
device.productMatrix
Shows product matrix details.
device.pvSignal
Shows if photovoltaic energy is available or not.
device.pvSignal.active
Shows whether photovoltaic is active or not.
device.remoteReset
Provides command to remote reset the device including requirement.
SRC
device.sensors.humidity
Shows the humidity room sensor value.
SRC
device.sensors.temperature
Shows the temperature room sensor value.
device.serial
Shows the serial number of connected device.
device.serial.internalComponents
Shows the list of built-in components in the device.
device.setDefaultValues
device.status
Presents if the device is OK.
device.thirdparty.manufacturer
Shows the third-party device manufacturer's name.
device.thirdparty.model
Shows the model-name of a third party device.
device.thirdparty.name
Shows the name of a third party device.
device.thirdparty.version.software
Shows the software version of a third party device.
device.time.daylightSaving
Shows the daylight saving time state and its validity period. Provides commands to configure it.
device.timeseries.burner.stops
Shows the frequency and reason for the device burner's stops.
device.timeseries.dhw.burner.stops
Shows the frequency and reason for the device DHW burner's stops.
device.timeseries.ignitionTimeSteps
Shows the ignition frequency separated into statistical classes for the device.
device.timeseries.monitoringIonization
Shows the ionization frequency separated into statistical classes for the device.
device.timeseries.water.pressure.peaks
Shows the water pressure peak frequency separated into statistical classes for the device.
device.timezone
Shows the timezone which is set on the device. Provides a command to set it.
device.type
Presents information if heat pump is split or mono device.
device.variant
Presents further information about the device-variant.
device.zigbee.active
Shows whether a zigbee is active or not.
device.zigbee.lqi
Shows the link quality indicator of the zigbee signal.
device.zigbee.parent.id
Shows the euid number of the parent device.
device.zigbee.parent.rx
Shows the received link quality indicator from device to his parent.
device.zigbee.parent.tx
Shows the transport link quality indicator from device to his parent.
device.zigbee.status
Shows the status of the zigbee.
ess.battery.usedAverage
Shows the usable energy average of the six modules and the whole System.
ess.configuration.backupBox
Shows the value for the reserved power which is used if the grid delivering is interrupted.
ess.configuration.systemType
Shows the types of the electrical energy system.
ess.energy.consolidated
Shows the charged energy of battery in cascade.
ess.features.backupReservedCapacity
Shows whether the BackupReservedCapacity currently activated. Provides command to de-/activate it.
ess.features.batterySleepMode
Shows whether the BatterySleepMode is currently activated. Provides command to de-/activate it.
ess.features.cyclicLoadCompressor
Shows whether the CyclicLoadCompressor is currently activated. Provides command to de-/activate it.
ess.features.optimalSelfConsumption
Shows whether the OptimalSelfConsumptionis currently activated. Provides command to de-/activate it.
ess.inverter.ac.power
Shows the current power of the inverter in watt.
Battery, DevPortalEuDataActRead
ess.operationState
Shows the status of the electrical energy operation state.
ess.power
Shows power of battery.
ess.power.feedInLimitation.consolidated
Shows power feed in limitation in cascade.
ess.power.maximum.charge.consolidated
Shows power maximum charge in cascade.
ess.power.maximum.discharge.consolidated
Shows power maximum discharge in cascade.
ess.power.nominal.charged.consolidated
Shows batteries charged nominal power in cascade.
ess.power.nominal.discharged.consolidated
Shows batteries discharged nominal power in cascade.
ess.power.nominal.inverter
Shows the three-phase inverter maximum nominal power.
ess.power.nominal.inverter.consolidated
ess.sensors.temperature.ambient
Shows the temperature and the status of the ambient temperature sensor.
Battery
ess.stateOfCharge
Shows the state of charge in percent.
ess.transfer.charge.cumulated
Shows the statistic values of charging the battery in different periods in wattHour.
ess.transfer.discharge.cumulated
Shows the throughput of electrical energy of the battery this day.
ess.version.hardware
Shows information about hardware version.
ems
ems.control.vcs.N.status
Shows the VCS control algorithm's current status.
ems.heatingRod.connectionPoint
Shows the heating rod connection type in the HEMS.
ems.hoca.features.allowBatteryChargingFromTheGrid
Shows whether the AllowBatteryChargingFromTheGridis currently activated.
ems.hoca.features.photovoltaicExcessToPvHeater
Shows the photovoltaic excess to PV heater mode state. Provides command to de/activate it.
ems.hoca.features.tariffBasedFinancialOptimization
Shows whether the TariffBasedFinancialOptimization is currently activated.
ems.hoca.features.vcsOverloadProtection
Shows wether the OverloadProtection for the Vehicle Charging Station is currently activated.
ems.hoca.features.vehicleChargingStationAllowBatteryDischarge
Shows the state of the vehicle charging station battery usage configuration. Provides commands to it.
ems.kpi
Shows Key Performance Indicators measured by HEMS.
ems.tariffs.feedIn
Shows the price of energy production in a given time period
ems.tariffs.heating
Shows the price of energy consumption in a given time period
ems.tariffs.household
Floor heating (FHT)
fht.configuration.floorCoolingCondensationShutdownMargin
Shows the emergency margin for the condensation threshold.
fht.configuration.floorCoolingCondensationThreshold
Shows the minimal temperature of the floor to prevent dew condensation.
fht.configuration.floorHeatingDamageProtectionThreshold
Shows the maximal temperature of the floor to prevent its damage. Provides a command to set it.
fht.operating.modes.active
Shows the currently active mode of the floor heating.
SRC
fht.operating.modes.cooling
Shows the cooling mode state of the floor heating.
SRC
fht.operating.modes.heating
Shows the heating mode state of the floor heating.
SRC
fht.operating.modes.standby
Shows the stand by mode state of the floor heating.
SRC
fht.sensors.temperature.supply
Shows information related with temperature sensor located on the flow pipe of the FHT.
fht.valve
Shows FHT valve type. Provides a command to set it.
fht.valve.state
Shows the valve state (close/open).
Fuel cell
fuelCell.burner.process
Shows burner process values like activation, air volume flow, fan speed and fan power.
fuelCell.coolingWater
Shows details of the cooling water of the fuel cell.
fuelCell.electricalEnergyConsumption.value
Shows the consumption of electrical energy.
fuelCell.errors.raw
Shows the list of raw errors returned by the fuel cell.
fuelCell.gas.details
Shows details about the first gas volume flow, second gas volume flow, gas hydrogen concentration and the booster pump power.
fuelCell.gas.exhaust
Shows information of the exhaust gas.
fuelCell.information.software.thirdParty
Shows the software versions of the different boards of the fuel cell.
fuelCell.managers.energy
Shows whether the electrical energy history should be reset or not.
fuelCell.managers.energy.prediction.power.consumption
Contains the predicted consumption of electrical energy in watt hour.
fuelCell.managers.energy.prediction.runtime
Shows the predicted runtime of the fuel cell unit.
fuelCell.managers.energy.timeTillNextStart
The feature shows time till next start in hours
Fuel cell
fuelCell.operating.modes.active
Shows current active operating mode on the device and provides command to change it.
Fuel cell
fuelCell.operating.modes.chimneySweeperMode
Shows whether the holidayWithFuelCellOn operating mode is active now.
Fuel cell
fuelCell.operating.modes.ecological
Shows whether the ecological operating mode is active now.
Fuel cell
fuelCell.operating.modes.economical
Shows whether the economical operating mode is active now.
Fuel cell
fuelCell.operating.modes.energyControlled
Shows whether the energyControlled operating mode is active now.
Fuel cell
fuelCell.operating.modes.heatControlled
Shows whether the heatControlled operating mode is active now.
Fuel cell
fuelCell.operating.modes.holidayWithFuelCellOff
Fuel cell
fuelCell.operating.modes.holidayWithFuelCellOn
Fuel cell
fuelCell.operating.modes.maintenance
Shows whether the maintenance operating mode is active now.
Fuel cell
fuelCell.operating.modes.party
Fuel cell
fuelCell.operating.modes.standby
Shows whether the Standby operating mode is active now.
Fuel cell, DevPortalEuDataActRead
fuelCell.operating.phase
Shows information about current phase which the fuel cell is in.
fuelCell.oxidation.preferential
Shows information about the preferential oxidation.
Fuel cell
fuelCell.power.production
Shows the amount of energy produced by the fuel-cell in kwH
fuelCell.power.production.lastTwoYears
Shows the generated electrical energy over the last two years.
fuelCell.prediction.heating.deficit
Shows information about the total heating deficit.
fuelCell.sensors.temperature.return
Shows information about flow return temperature sensor, i.e. water temperature on return to the boiler from heating installation.
fuelCell.sensors.temperature.supply
Shows information about flow temperature sensor, i.e. water temperature on return to the boiler from heating installation.
fuelCell.sequence
Shows the sequence numbers of the fuel cell.
fuelCell.statistics
Shows statistics of fuel Cell.
fuelCell.temperature.processor
Shows different temperatures of fuel cell processor.
fuelcell
fuelcell.status.extended
Shows the fuel cell extended status information.
Gateway
gateway.bmuconnection
The status, of the connection between the Boiler Management Unit and the Boiler.
gateway.devices
List the devices connected to the gateway.
gateway.wifi
Shows information related to the WiFi in a gateway.
hb2
hb2.veryLongComfortMode
Shows whether the veryLongComfortMode is active on Heatbox2 or not.
Heating
Heating+, DevPortalEuDataActRead
heating.boiler.airflaps.N.position.current
Shows the current position of the air-flaps.
heating.boiler.ash.level.current
Shows the current fill-level of the ash-container.
heating.boiler.operating.phase
Shows the connected solid fuel boiler state.
heating.boiler.pumps.circuit
Shows the boiler-circuit-pump current state.
heating.boiler.pumps.circuit.power.current
Shows the boiler-circuit pump current power.
heating.boiler.pumps.internal
Shows if circulation pump is on for circuit
heating.boiler.pumps.internal.current
Shows the current value in percent for the internal pump.
heating.boiler.pumps.internal.target
Shows the target-value in percent for the internal pump.
heating.boiler.sensors.temperature.commonReturn
Shows the common return temperature with a unit and its sensor status.
heating.boiler.sensors.temperature.commonSupply
Shows information related with temperature sensor located on the exit of heating installation of boiler.
heating.boiler.sensors.temperature.main
Shows information related with main temperature sensor.
heating.boiler.serial
(Deprecated for E3 devices will be replaced by device.serial) Shows the serial number of connected boiler.
heating.boiler.temperature
Shows the value of boiler temperature.
heating.boiler.temperature.current
Contains information about set temperature of the primary heating circuit.
heating.buffer.charging.level.bottom
Shows the buffer cylinder charging state at the bottom.
heating.buffer.charging.level.middle
Shows the buffer cylinder charging state in the middle.
heating.buffer.charging.level.top
Shows the buffer cylinder charging state at the top.
heating.buffer.charging.level.total
Shows the buffer cylinder charging state in total.
heating.buffer.hysteresis
Shows information about the heat medium buffer temperature.
heating.buffer.sensors.temperature.main
Shows information about current value and status of the buffer temperature sensor.
heating.buffer.sensors.temperature.midTop
Shows the status and the value of the middle-top temperature sensor in the heating water buffer.
heating.buffer.sensors.temperature.top
Shows the buffer cylinder top temperature sensor details.
heating.bufferCylinder.charging.level.bottom
Shows the buffer cylinder charging bottom level.
heating.bufferCylinder.charging.level.middle
Shows the buffer cylinder charging middle level.
heating.bufferCylinder.charging.level.top
Shows the buffer cylinder charging top level.
heating.bufferCylinder.charging.level.total
Shows the buffer cylinder charging level in total.
heating.bufferCylinder.hysteresis
Shows information about the heat medium buffer temperature in kelvin
heating.bufferCylinder.sensors.temperature.bottom
Shows the buffer cylinder bottom temperature sensor details.
heating.bufferCylinder.sensors.temperature.main
heating.bufferCylinder.sensors.temperature.midBottom
Shows the buffer cylinder middle-bottom temperature sensor details.
heating.bufferCylinder.sensors.temperature.middle
Shows the buffer cylinder middle temperature sensor details.
heating.bufferCylinder.sensors.temperature.midTop
Shows the buffer cylinder middle-top temperature sensor details.
heating.bufferCylinder.sensors.temperature.top
heating.burners
Provides the device enabled burners list.
heating.burners.modulation.total
Shows the total modulation of the burner cascade.
heating.burners.N.automatic
DEPRECATED in favor of heating.burners.0.errorStatus
heating.burners.N.demand.modulation
Shows information related with target burner modulation.
heating.burners.N.demand.temperature
Shows information related with target burner temperature.
heating.burners.N.errorStatus
heating.burners.N.manualActivation
Shows whether the burner got activated manually and provides the commands to do so.
heating.burners.N.modulation
Shows information related with current burner modulation.
heating.burners.N.preConditions
Shows the burner start preconditions.
heating.burners.N.sensors.o2
Shows the current value, unit and the status of the oxygen probe.
heating.burners.N.statistics
Shows statistics of burner.
heating.calculated.temperature.outside
Shows the calculated outside temperature using the sensor readings and the damping factor into account.
heating.callForHeat
Shows whether the N heating circuit is enabled.
heating.callForHeat.configuration.regulation
Shows the regulation modes for the CallForHeat function.
heating.callForHeat.demand
Shows whether there is a demand for the CallForHeat function.
heating.callForHeat.heating.curve.presets
Shows the heating curve available presets for the Call For Heat function.
heating.callForHeat.pump
Shows whether the pump for CallForHeat is active or not.
heating.callForHeat.sensors.temperature
Shows the current flow temperature for the Call For Heat function.
heating.cascade
Shows whether the connected device is part of a cascade.
heating.cascade.dhw.mode
heating.cascade.members.N.burner
Shows the heating cascade member burner status.
heating.cascade.members.N.burners.modulation.total
Shows the heating cascade member total modulation.
heating.cascade.sensors.temperature.commonSupply
Shows the common flow temperature over all cascade members.
heating.cascade.temperature.commonSupply
Contains the common supply temperature setpoint and the command to change the setpoint over all devices.
heating.circuits
Circuits information
heating.circuits.N.circulation.pump
Shows if circulation pump is on for circuit N.
heating.circuits.N.circulation.secondaryPump
Shows if secondary circulation pump is on for circuit 0.
heating.circuits.N.configuration.summerEco.absolute
Allows de-/activation of the summerEco-function and setting of the desired threshold.
DevPortalHeatingRead, DevPortalEuDataActRead
heating.circuits.N.cooling.hysteresis
Shows the device cooling activation thresholds. Provides commands to set them.
heating.circuits.N.cooling.hysteresis.switch
Shows the hysteresis switch on / off relative to the current target value of heating circuit temperature for cooling. Provides commands to set them.
heating.circuits.N.dhw.pumps.circulation.schedule
Shows schedule of circulation for circuit N and provides command to set a new one.
heating.circuits.N.dhw.schedule
Shows schedule of domestic hot water for circuit N and provides command to set a new one.
heating.circuits.N.frostprotection
Shows whether frost protection of installation is turn on in device.
heating.circuits.N.heating.curve
Shows values related to heating curve and provides commands to modify it.
heating.circuits.N.heating.curve.presets
Shows available presets for the heating curve of TT-circuits.
heating.circuits.N.heating.hysteresis.switch
Shows the hysteresis switch on / off relative to the current target value of heating circuit temperature for heating. Provides commands to set them.
heating.circuits.N.heating.schedule
Shows heating schedule for circuit N and provides command to set a new one.
heating.circuits.N.operating.modes.active
heating.circuits.N.operating.modes.cooling
Shows whether the cooling operating mode is active now.
heating.circuits.N.operating.modes.dhw
Shows whether the DHW operating mode is active now.
heating.circuits.N.operating.modes.dhwAndHeating
Shows whether the DHW and Heating operating mode is active now.
heating.circuits.N.operating.modes.dhwAndHeatingCooling
Shows whether the DHW and HeatingCooling operating mode is active now.
heating.circuits.N.operating.modes.forcedNormal
Shows whether the Forced Normal operating mode is on, which means that the external controller is taking care of the device.
heating.circuits.N.operating.modes.forcedReduced
Shows whether the Forced Reduced operating mode is on, which means that the external controller is taking care of the device.
heating.circuits.N.operating.modes.heating
Shows whether the Heating operating mode is active now.
heating.circuits.N.operating.modes.heatingCooling
Shows whether the HeatingCooling operating mode is active now.
heating.circuits.N.operating.modes.normalStandby
Shows whether the NormalStandby operating mode is active now.
heating.circuits.N.operating.modes.standby
Shows whether the Standby operating mode is active now, which means device will only start to protect installation from frost.
heating.circuits.N.operating.programs.active
Shows current active operating program enabled on the device.
heating.circuits.N.operating.programs.comfort
Shows information related to comfort program. Also provides the commands to enable/disable it and change the Comfort temperature value.
heating.circuits.N.operating.programs.comfortCooling
Shows the 'Comfort cooling' operating program activation and its desired temperature for the device. Provides commands to de-/activate it and set the temperature.
heating.circuits.N.operating.programs.comfortCoolingEnergySaving
Shows whether the device is in the 'Energy saving' operating mode while the 'Comfort cooling' program was scheduled.
heating.circuits.N.operating.programs.comfortEnergySaving
Shows whether the device is in the 'Energy saving' operating mode while the 'Comfort' program was scheduled.
heating.circuits.N.operating.programs.comfortHeating
Shows the 'Comfort heating' operating program activation and its desired temperature for the device. Provides commands to de-/activate it and set the temperature.
heating.circuits.N.operating.programs.dhwPrecedence
Shows the 'DHW precedence' operating program activation.
heating.circuits.N.operating.programs.eco
Shows information related to Eco program. Also provides the commands to enable/disable it.
heating.circuits.N.operating.programs.external
Shows information related to External program, which is set when device is handled by external controller.
heating.circuits.N.operating.programs.fixed
Shows whether Fixed program is active.
heating.circuits.N.operating.programs.forcedLastFromSchedule
Shows information related to Forced Last From Schedule program. This is last program which was enabled by schedule and it's sustained until deactivation. It can be activated if device is in any of heating operating modes.
heating.circuits.N.operating.programs.frostprotection
Shows the 'Frost protection' operating program activation.
heating.circuits.N.operating.programs.heatDissipation
Shows the 'Heat dissipation' program status.
heating.circuits.N.operating.programs.holiday
Shows information related to Holiday program and provides command to set it.
heating.circuits.N.operating.programs.manual
Shows information related to manual program. Also provides the commands to enable/disable it and change the Manual temperature value.
heating.circuits.N.operating.programs.mixerSaving
Shows the 'Mixer saving' program status.
heating.circuits.N.operating.programs.noDemand
Shows that the standby mode is the standby for the zone mode.
heating.circuits.N.operating.programs.normal
Shows whether the Normal temperature program is active and provides command to set the temperature value.
heating.circuits.N.operating.programs.normalCooling
Shows the 'Normal cooling' operating program activation and its desired temperature for the device. Provides commands to de-/activate it and set the temperature.
heating.circuits.N.operating.programs.normalCoolingEnergySaving
Shows whether the device is in the 'Energy saving' operating mode while the 'Normal cooling' program was scheduled.
heating.circuits.N.operating.programs.normalEnergySaving
Shows whether the device is in the 'Energy saving' operating mode while the 'Normal' program was scheduled.
heating.circuits.N.operating.programs.normalHeating
Shows the 'Normal heating' operating program activation and its desired temperature for the device. Provides commands to de-/activate it and set the temperature.
heating.circuits.N.operating.programs.reduced
Shows whether the Reduced temperature program is active and provides command to set the temperature value
heating.circuits.N.operating.programs.reducedCooling
Shows the 'Reduced cooling' operating program activation and its desired temperature for the device. Provides commands to de-/activate it and set the temperature.
heating.circuits.N.operating.programs.reducedCoolingEnergySaving
Shows whether the device is in the 'Energy saving' operating mode while the 'Reduced cooling' program was scheduled.
heating.circuits.N.operating.programs.reducedEnergySaving
Shows whether the device is in the 'Energy saving' operating mode while the 'Reduced' program was scheduled.
heating.circuits.N.operating.programs.reducedHeating
Shows the 'Reduced heating' operating program activation and its desired temperature for the device. Provides commands to de-/activate it and set the temperature.
heating.circuits.N.operating.programs.screedDrying.heatpump
Shows weather the heatpump is free to be used for screed-drying.
heating.circuits.N.operating.programs.standby
Shows whether Standby program is active. It is active in between heating schedule entries.
heating.circuits.N.operating.programs.summerEco
Shows that the summer eco mode is active or not.
heating.circuits.N.operating.programs.summerSaving
Shows the 'Summer saving' program status.
Heat pump
heating.circuits.N.remoteController
Shows remote controller assigned to the heating circuit.
heating.circuits.N.sensors.humidity.dewpoint
Shows the dewpoint detector status.
heating.circuits.N.sensors.temperature.room
Shows information about room temperature sensor.
heating.circuits.N.sensors.temperature.supply
Shows information about supply temperature sensor, i.e. water temperature on exit from boiler to heating installation.
heating.circuits.N.temperature
Shows the value of the circuit target temperature.
heating.circuits.N.temperature.levels
Shows the lower and the upper limit of the supply-temperature.
heating.circuits.N.zone.demand
Shows if at least one zone that is hooked up to this heating circuit has a demand for heat.
heating.circuits.N.zone.mode
Shows if zone is connected to heating circuit.
Fuel cell
heating.co2.saving
Shows statistics of CO2 saving. Deprecated in favor of heating.co2.saving.raw
Shows raw statistics of CO2 saving
heating.compressors
Shows the list of enabled compressors.
Heat pump
heating.compressors.N.heat.production.cooling.week
Shows the power consumption of the first compressor for cooling during the current week.
Heat pump
heating.compressors.N.heat.production.current
Shows the current heat generation of the compressor.
Heat pump
heating.compressors.N.heat.production.dhw.week
Shows the heat production of the compressor for DHW during the current week.
Heat pump
heating.compressors.N.heat.production.heating.week
Shows the power consumption of the first compressor for heating during the current week.
heating.compressors.N.heater.crankcase
Shows the first compressor's crankcase heater status.
Heat pump
heating.compressors.N.heatTarget
Shows what the compressor is currently heating.
heating.compressors.N.operating.temperature.current
Shows the compressed and recompressed operating point temperature of the compressor.
heating.compressors.N.power
Shows the compressor power. Provides a command to set it manually.
Heat pump
heating.compressors.N.power.consumption.cooling
Shows statistics of power usage for cooling down rooms by the first compressor. It is shown in `kWh`.
Heat pump
heating.compressors.N.power.consumption.cooling.week
Heat pump
heating.compressors.N.power.consumption.current
Shows the current power consumption of the first compressor.
Heat pump
heating.compressors.N.power.consumption.dhw
Shows statistics of power usage for heating up DHW by the first compressor. It is shown in `kWh`.
Heat pump
heating.compressors.N.power.consumption.dhw.week
Shows the power consumption of the first compressor for dhw during the current week.
Heat pump
heating.compressors.N.power.consumption.heating
Shows statistics of power usage for cooling up rooms by the first compressor. It is shown in `kWh`.
Heat pump
heating.compressors.N.power.consumption.heating.week
Heat pump
heating.compressors.N.power.consumption.total
Shows statistics of total power usage by the first compressor. It is shown in `kWh`.
heating.compressors.N.sensors.power
Shows information about the power and the status of the compressors.
heating.compressors.N.sensors.pressure.inlet
Shows the first compressor inlet pressure sensor details.
heating.compressors.N.sensors.temperature.ambient
Shows the temperature of the room the first compressor is placed in.
heating.compressors.N.sensors.temperature.inlet
Shows the first compressor outlet pressure sensor details.
heating.compressors.N.sensors.temperature.motorChamber
Shows the first compressor motor chamber temperature sensor details.
heating.compressors.N.sensors.temperature.oil
Shows the first compressor oil temperature sensor details.
heating.compressors.N.sensors.temperature.outlet
Shows the first compressor outlet temperature sensor details.
heating.compressors.N.sensors.temperature.overheat
Shows the first compressor overheat temperature sensor details.
heating.compressors.N.speed.current
Shows the first compressor motor liquid current speed.
heating.compressors.N.speed.setpoint
Shows the first compressor motor liquid speed setpoint.
heating.compressors.N.statistics
Shows statistics of compressor N.
heating.compressors.N.statistics.load
Shows load-classes of compressor N.
heating.compressors.N.volumeFlow.minimum
Shows the minimal liquid volume flow for the secondary heat exchanger.
heating.condensors.N.sensors.temperature.liquid
Shows the status and the value of the condensors liquid temperature.
heating.condensors.N.sensors.temperature.subcooling
Shows the subcooling of the first condensor.
heating.configuration.buffer.temperature.max
Shows the maximum temperature of the Hot water buffer. Also provides the command to set it
heating.configuration.bufferCylinderSize
Shows object configuration about buffer cylinder size in L.
heating.configuration.centralHeatingCylinderSize
Shows object configuration about central heating cylinder size in L.
heating.configuration.dhw.dryContact
Shows if aqua stat for the DHW is configured.
heating.configuration.dhw.highDemand.threshold
Configures the high demand threshold value for the tapped volume
heating.configuration.dhw.highDemand.timeframe
Configures the high demand timeframe value for the tapped volume
heating.configuration.dhw.temperature.comfortCharging
(DEPRECATED) Sets the target DHW temperature for comfort charging.
heating.configuration.dhw.temperature.dhwCylinder.max
Shows the maximum temperature of the Domestic Hot Water tank. Also provides the command to set it
heating.configuration.dhw.temperature.hotWaterStorage.max
Shows the maximum temperature of the Domestic Hot Water tank. Also provides the command to set it, DEPRECATED in favor of heating.configuration.dhw.temperature.dhwCylinder.max
heating.configuration.dhw.temperature.minimumComfort
DEPRECATED it will be replaced by heating.dhw.configuration.temperature.minimumComfort
heating.configuration.dhwCylinderPump
Shows the limits of the dhwCylinder pump.
heating.configuration.dhwCylinderSize
Shows object configuration about dhw cylinder size in L.
heating.configuration.dhwHeater
Shows weather the electric heater inside the DHW-tank is free to be used.
heating.configuration.flow.temperature.max
Shows the maximum flow temperature. Also provides the command to set it
heating.configuration.flow.temperature.min
Shows the minimal flow temperature. Also provides the command to set it
heating.configuration.fuel.capacity
Shows the device maximal fuel tank capacity. Provides a command to set it.
heating.configuration.fuel.need
Shows values related to the fuel-need.
heating.configuration.gasType
Shows the configured gas-type.
heating.configuration.heatingRod.dhw
Shows whether the electric heater for hot water is free to be used for heating DHW. For legacy devices, the general usage of the electrical heater needs to be granted first!
heating.configuration.heatingRod.heating
Shows whether the electric heater for hot water is free to be used for heating rooms. For legacy devices, the general usage of the electrical heater needs to be granted first!
heating.configuration.heatingRod.nominalPower
Shows the nominal power of the heating rod.
heating.configuration.houseHeatingLoad
Shows object configuration heating load per square meter in kWh/year.
heating.configuration.houseLocation
heating.configuration.houseOrientation
Shows object orientation in degrees.
heating.configuration.hydraulicMatrix
Shows the values of the hydraulicMatrix
heating.configuration.internalPumpOne
Shows the limits of the internal pump one.
heating.configuration.internalPumps
Shows the limits of the pump.
heating.configuration.internalPumpTwo
Shows the limits of the internal pump two.
heating.configuration.pressure.total
Contains information about the pressure inside the system.
heating.configuration.smartGrid.heatingRod
Up to which level can SG Ready influence the heating-rod?
heating.configuration.temperature.outside.DampingFactor
Shows the damping factor for outside temperature. Also provides a command to change it.
heating.controller.serial
Shows serial number of the controller.
heating.coolingCircuits.N.reverse
Shows whether a the cooling circuit is used reverse or not
heating.coolingCircuits.N.type
Shows the cooling circuit controller type.
Heat pump, DevPortalEuDataActRead
heating.cop.cooling
Shows the cooling cop.
heating.cop.dhw
Shows the dhw COP.
heating.cop.green
Shows the green electricity COP.
heating.cop.heating
Shows the heating COP.
heating.cop.total
Shows the total COP.
heating.device.chargingScheme
Presents charging scheme of the suction module.
heating.device.fuel.current
Shows the current fuel tank level. Provides commands to adjust it.
heating.device.fuel.minimal
Shows the minimal filling value of the fuel tank on which the user get a notification to refill.
heating.device.mainECU
Shows information about the mainECU.
heating.device.software
Presents further information about the device-software.
heating.device.status
Shows the current device status.
heating.device.time
Provides command to set time and date.
heating.device.variant
heating.dhw
Shows whether the domestic hot water is activated/present on the heating installation.
heating.dhw.actuator
Shows the current state and status of the actuator for DHW preparation.
heating.dhw.charging
Shows whether the hot water charging in DHW storage is active.
heating.dhw.comfort
(Deprecated - it will be replaced by heating.dhw.operating.modes.comfort/eco/active). Shows if heat-exchanger for the DHW is kept warm all the time is active. Also provides the commands to activate/deactivate it.
heating.dhw.configuration.dryContact
heating.dhw.configuration.highDemand.threshold
heating.dhw.configuration.highDemand.timeframe
heating.dhw.configuration.pumps.circulation.parallelDhwHeating
Shows if the dhw circulation pump is running in parallel with dhw heating. Also provides the command to de-/activate it.
heating.dhw.configuration.pumps.circulation.parallelHygiene
Shows if the dhw circulation pump is running in parallel with hygiene. Also provides the commands to de-/activate it.
heating.dhw.configuration.pumps.circulation.triggerCycleDuration
Shows the trigger for cycle duration of the dhw circulation pump. Also provides command to set it.
heating.dhw.configuration.temperature.comfortCharging
heating.dhw.configuration.temperature.dhwCylinder.max
Shows the heat pump's minimum comfort temperature. Provided a command to set it.
heating.dhw.dhwCylinder.frostprotection
Shows whether frost protection for dhwCylinder is turn on in device.
heating.dhw.dryContact
Shows if aqua stat for the DHW is active.
heating.dhw.hygiene
This feature allow to enable the hygiene-function. The hygiene-function heats up the DHW to a setpoint (heating.dhw.temperature.hygiene) high enough to kill any legionella bacteria in the system. If the function is enabled it will be activated according to the defined trigger (heating.dhw.hygiene.trigger). If the function is currently executed, the active-flag will be set to true. Manual activation is possible using the activate-command.
This feature defines when the hygiene function will be executed if it is enabled (heating.dhw.hygiene). The function can be executed once per week on a defined weekday and time or daily. In the latter case, the property weekdays contains all weekdays, otherwise only the one weekday on which the function should run.
heating.dhw.oneTimeCharge
Shows whether one time charge of dhw is active. Also provides the commands to activate/deactivate it.
heating.dhw.operating.modes.active
Shows the active operating mode for DHW. Provides a command to set it.
heating.dhw.operating.modes.balanced
Shows the 'Balanced' operating mode activation for DHW.
Shows the 'Comfort' operating mode activation for DHW.
heating.dhw.operating.modes.eco
Shows the 'Eco' operating mode activation for DHW.
heating.dhw.operating.modes.efficient
Shows the state of 'Efficient' domestic hot water charge operating mode.
heating.dhw.operating.modes.efficientWithMinComfort
Shows the state of 'Efficient with min. comfort' domestic hot water charge operating mode.
heating.dhw.operating.modes.off
Shows whether the off operating mode is active now.
heating.dhw.pumps.circulation
Shows the status of the Domestic Hot Water circulation pump.
heating.dhw.pumps.circulation.schedule
Shows pumps circulation schedule of domestic hot water.
heating.dhw.pumps.primary
Shows the status of the Domestic Hot Water primary pump.
heating.dhw.pumps.secondary
Shows whether the domestic hot water pump in the secondary circuit is on or off. This configuration is used for compact devices.
heating.dhw.scaldProtection
Shows if the DHW Scald protection functionality is active. Provides command to de-/activate it.
heating.dhw.schedule
Shows schedule of domestic hot water.
heating.dhw.sensors.dhwCylinder.rustSurveillance.anode
Shows information about current value and status of the anode control sensor.
heating.dhw.sensors.temperature.dhwCylinder
Shows information about hot water storage sensor.
heating.dhw.sensors.temperature.dhwCylinder.bottom
heating.dhw.sensors.temperature.dhwCylinder.midBottom
heating.dhw.sensors.temperature.dhwCylinder.middle
heating.dhw.sensors.temperature.dhwCylinder.top
heating.dhw.sensors.temperature.hotWaterStorage
heating.dhw.sensors.temperature.hotWaterStorage.bottom
heating.dhw.sensors.temperature.hotWaterStorage.midBottom
heating.dhw.sensors.temperature.hotWaterStorage.middle
heating.dhw.sensors.temperature.hotWaterStorage.top
heating.dhw.sensors.temperature.outlet
Shows information related to Domestic Hot Water temperature sensor.
heating.dhw.sensors.temperature.tankLoadSystem.return
Shows information about tankloadsystem sensor.
heating.dhw.sensors.temperature.tankLoadSystem.supply
Shows information about tank load system sensor.
This feature defines the temperature to which the dhw will be heated up in order to kill any legionella bacterias in the pipes. The scald protection will be overriden by this function. An active scald protection will cap the maximum dhw temperature at 65° Celsius.
heating.dhw.temperature.hysteresis
Shows the hysteresis value of the Domestic Hot Water temperature in heat pumps. Also provides the command to set it
heating.dhw.temperature.levels
Shows available DHW ranges and defaults for E3 systems.
heating.dhw.temperature.main
Shows the desired value of the Domestic Hot Water temperature. Also provides the command to set it
heating.dhw.temperature.temp2
Shows the desired value of the Domestic Hot Water Temp 2 temperature. Also provides the command to set it
heating.economizers.N.sensors.temperature.liquid
Shows information about hydraulic separator temperature sensor.
heating.evaporators.N.heater.base
Shows the state of the evaporator's base heater.
heating.evaporators.N.sensors.temperature.liquid
Shows the evaporator liquid temperature sensor details.
heating.evaporators.N.sensors.temperature.overheat
Shows the evaporator overheat temperature sensor details.
heating.external.lock
Contains information whether device currently is locked by some external lock influence.
Heating+
heating.flue.sensors.o2.lambda
Shows the current calculated value of oxygen and the lambda sensor connection status in the heating system.
Heating+
heating.flue.sensors.temperature.main
Shows the status and measured temperature of the flue gas sensor.
heating.fuelCell.burner.process
(DEPRECATED it will be replaced by fuelCell.burner.process) Shows burner process values like activation, air volume flow, fan speed and fan power.
heating.fuelCell.coolingWater
(DEPRECATED it will be replaced by fuelCell.coolingWater) Shows details of the cooling water of the fuel cell.
heating.fuelCell.electricalEnergyConsumption.value
DEPRECATED it will be replaced by fuelCell.electricalEnergyConsumption.value
heating.fuelCell.errors.raw
DEPRECATED it will be replaced by fuelCell.errors.raw
heating.fuelCell.gas.details
(DEPRECATED it will be replaced by fuelCell.gas.details) Shows details about the first gas volume flow, second gas volume flow, gas hydrogen concentration and the booster pump power.
heating.fuelCell.gas.exhaust
(DEPRECATED it will be replaced by fuelCell.gas.exhaust) Shows information of the exhaust gas.
heating.fuelCell.information.software.thirdParty
(DEPRECATED it will be replaced by fuelCell.information.software.thirdParty) Shows the software versions of the different boards of the fuel cell.
heating.fuelCell.managers.energy
DEPRECATED it will be replaced by fuelCell.managers.energy
heating.fuelCell.managers.energy.prediction.power.consumption
DEPRECATED it will be replaced by fuelCell.managers.energy.prediction.power.consumption
heating.fuelCell.managers.energy.prediction.runtime
DEPRECATED it will be replaced by fuelCell.managers.energy.prediction.runtime
heating.fuelCell.managers.energy.timeTillNextStart
DEPRECATED it will be replaced by fuelCell.managers.energy.timeTillNextStart
Fuel cell
heating.fuelCell.operating.modes.active
(DEPRECATED it will be replaced by fuelCell.operating.modes.active) Shows current active oprtating mode on the device and provides command to change it.
Fuel cell
heating.fuelCell.operating.modes.chimneySweeperMode
(DEPRECATED it will be replaced by fuelCell.operating.modes.chimneySweeperMode) Shows whether the holidayWithFuelCellOn operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.ecological
(DEPRECATED it will be replaced by fuelCell.operating.modes.ecological) Shows whether the ecological operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.economical
(DEPRECATED it will be replaced by fuelCell.operating.modes.economical) Shows whether the economical operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.energyControlled
(DEPRECATED it will be replaced by fuelCell.operating.modes.energyControlled) Shows whether the energyControlled operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.heatControlled
(DEPRECATED it will be replaced by fuelCell.operating.modes.heatControlled) Shows whether the heatControlled operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.holidayWithFuelCellOff
(DEPRECATED it will be replaced by fuelCell.operating.modes.holidayWithFuelCellOff) Shows whether the holidayWithFuelCellOff operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.holidayWithFuelCellOn
(DEPRECATED it will be replaced by fuelCell.operating.modes.holidayWithFuelCellOn) Shows whether the holidayWithFuelCellOn operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.maintenance
(DEPRECATED it will be replaced by fuelCell.operating.modes.maintenance) Shows whether the maintenance operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.party
(DEPRECATED it will be replaced by fuelCell.operating.modes.party) Shows whether the party operating mode is active now.
Fuel cell
heating.fuelCell.operating.modes.standby
(DEPRECATED it will be replaced by fuelCell.operating.modes.standby) Shows whether the Standby operating mode is active now.
heating.fuelCell.operating.phase
(DEPRECATED it will be replaced by fuelCell.operating.phase) Shows information about current phase which the fuel cell is in.
heating.fuelCell.oxidation.preferential
(DEPRECATED it will be replaced by fuelCell.oxidation.preferential) Shows information about the preferential oxidation.
Fuel cell
heating.fuelCell.power.production
(DEPRECATED it will be replaced by fuelCell.power.production) Shows the amount of energy produced by the fuel-cell in kwH
heating.fuelCell.power.production.lastTwoYears
heating.fuelCell.prediction.heating.deficit
DEPRECATED it will be replaced by fuelCell.prediction.heating.deficit
heating.fuelCell.sensors.temperature.return
(DEPRECATED it will be replaced by fuelCell.sensors.temperature.return) Shows information about flow return temperature sensor, i.e. water temperature on return to the boiler from heating installation.
heating.fuelCell.sensors.temperature.supply
(DEPRECATED it will be replaced by fuelCell.sensors.temperature.supply) Shows information about flow temperature sensor, i.e. water temperature on return to the boiler from heating installation.
heating.fuelCell.sequence
(DEPRECATED it will be replaced by fuelCell.sequence) Shows the sequence numbers of the fuel cell.
heating.fuelCell.statistics
(DEPRECATED it will be replaced by fuelCell.statistics) Shows statistics of fuel Cell.
heating.fuelCell.temperature.processor
(DEPRECATED it will be replaced by fuelCell.temperature.processor) Shows different temperatures of fuel cell processor.
Heating
heating.gas.consumption.dhw
Shows statistics of gas usage for heating up the DHW. It is shown in `Wh`.
Fuel cell
heating.gas.consumption.fuelCell
Shows statistics of gas usage of the fuel-cell.
heating.gas.consumption.fuelCell.lastTwoYears
Shows the fuel cell gas consumption over the last two years.
Heating
heating.gas.consumption.heating
heating.gas.consumption.summary.dhw
Shows cumulated statistics of consumed gas for DHW
heating.gas.consumption.summary.heating
Shows cumulated statistics of generated heat energy for space climate heating
Heating
heating.gas.consumption.total
Shows statistics of gas usage. It is shown in cubicMeters.
Heating+
heating.heat.production.cooling
Shows statistics of generated heat energy for cooling
Heating+
heating.heat.production.current
Shows the current heat-generation of the system
heating.heat.production.currentYear.cooling
heating.heat.production.currentYear.dhw
heating.heat.production.currentYear.heating
Heating+
heating.heat.production.dhw
Shows statistics of generated heat energy for space climate heating.
Heating+
heating.heat.production.heating
heating.heat.production.summary.cooling
Shows cumulated statistics of generated heat energy for cooling.
heating.heat.production.summary.dhw
Shows cumulated statistics of generated heat energy for DHW.
heating.heat.production.summary.heating
Shows cumulated statistics of generated heat energy for space climate heating.
Heating+
heating.heat.production.total
Shows statistics of the total generated heat energy.
heating.heater.condensatePan
Shows if condensate pan heater is available. Provide a command to de-/active it.
heating.heater.fanRing
Shows if fan ring heater is available. Provide a command to de-/active it.
heating.heatingRod
Shows if heating rod available.
Heat pump
heating.heatingRod.heat.production.current
Shows the current heat-generation of the heating-rod (HWDE).
Heat pump
heating.heatingRod.heatTarget
Shows what the heating-rod is currently heating.
heating.heatingRod.maximumOutsideTemperature
Shows the maximum outside temperature when the e-heater can be switched on.
Heat pump
heating.heatingRod.power.consumption.current
Shows the current power consumption of the heating-rod (HWDE)
heating.heatingRod.power.consumption.currentYear.dhw
heating.heatingRod.power.consumption.currentYear.heating
Heat pump
heating.heatingRod.power.consumption.dhw
Shows statistics of power usage for heating up DHW by the heating rod (HWDE). It is shown in `kWh`.
Heat pump
heating.heatingRod.power.consumption.heating
Shows statistics of power usage for heating up rooms by the heating-rod (HWDE). It is shown in `kWh`.
heating.heatingRod.power.consumption.summary.dhw
heating.heatingRod.power.consumption.summary.heating
Heat pump
heating.heatingRod.power.consumption.total
heating.heatingRod.runtime
Shows the heating rod run time for two levels.
heating.heatingRod.statistics
Shows the starts and count of starts of the heating rod.
Heat pump
heating.heatingRod.status
Shows the active heating level of instantaneous e-heater.
heating.increasedReturn.temperature
Shows information about desired return Temperature of the interim system e.g. Temperature behind a built-in buffer when a system is supported with a return increase.
heating.inverters.N.sensors.power.current
Shows information about the current power and the status of the heat pump inverter.
heating.inverters.N.sensors.power.output
Shows information about the power and the status of the heat pump inverter.
heating.inverters.N.sensors.temperature.powerModule
Shows information about the current temperature and the status of the heat pump inverter power module.
heating.noise.reduction.levels.maxReduced
Shows if the device is currently running in noise-reduction-level 'maxReduced'.
heating.noise.reduction.levels.notReduced
Shows if the device is currently running in noise-reduction-level 'notReduced'.
heating.noise.reduction.levels.slightlyReduced
Shows if the device is currently running in noise-reduction-level 'slightlyReduced'.
heating.noise.reduction.operating.programs.active
DEPRECATED it will be replaced by heating.noise.reduction.operating.state
heating.noise.reduction.operating.programs.maxReduced
DEPRECATED!
heating.noise.reduction.operating.programs.notReduced
DEPRECATED!
heating.noise.reduction.operating.programs.slightlyReduced
DEPRECATED!
heating.operating.programs.holiday
heating.operating.programs.holidayAtHome
Shows information related to HolidayAtHome program and provides command to set it. If Holiday and HolidayAtHome are overlapping, holiday at home has priority
heating.outdoor.defrosting
Shows if the defrosting mode is active
heating.outdoor.defrosting.thermalEnergy
Shows the thermal energy of the defrosting mode and its unit
heating.power.consumption.cooling
Shows statistics of power usage for cooling. It is shown in `kWh`.
Heat pump
heating.power.consumption.current
Shows the current consumption of electrical energy.
heating.power.consumption.currentYear.cooling
heating.power.consumption.currentYear.dhw
heating.power.consumption.currentYear.heating
Heating
heating.power.consumption.dhw
Shows statistics of power usage for heating up the DHW. It is shown in `kWh`.
Heating
heating.power.consumption.heating
Shows statistics of power usage for heating up rooms. It is shown in `kWh`.
heating.power.consumption.summary.cooling
Shows cumulated statistics of power usage for cooling.
heating.power.consumption.summary.dhw
heating.power.consumption.summary.heating
Heating
heating.power.consumption.total
Shows statistics of power usage. It is shown in kWh. It supersedes heating.power.consumption.
heating.power.production.cumulative
(NEW version of heating.power.cumulativeProduced) Shows information about produced power.
Fuel cell
heating.power.production.current
(NEW version of heating.sensors.power.output) Shows information about power output.
heating.power.production.demandCoverage.current
Shows the heating device currently needed energy production.
heating.power.production.demandCoverage.raw
Shows raw statistics of demand coverage
heating.power.production.productionCoverage.current
Shows the currently produced energy consumption by the household.
heating.power.production.productionCoverage.raw
Shows raw statistics of production coverage
heating.power.purchase.cumulative
(NEW version of heating.power.cumulativePurchased) Shows information about purchased power.
heating.power.purchase.current
Shows information about currently purchased power.
heating.power.sold.cumulative
(NEW version of heating.power.cumulativeSold) Shows information about power feed into power grid.
heating.power.sold.current
Shows information about power currently feed into power grid.
heating.primaryCircuit.configuration.preVentilation
Shows the time for pre-ventilation after which the heatpump decides to start. Provides command to set time
heating.primaryCircuit.fans.N.current
Shows the primary circuit current fan and its status.
heating.primaryCircuit.sensors.rotation
Shows the primary circuit fan rotation speed.
heating.primaryCircuit.sensors.temperature.return
Shows information about the primary source's return-temperature of a heatpump.
heating.primaryCircuit.sensors.temperature.supply
Shows information about the primary source's supply-temperature of a heatpump.
heating.primaryCircuit.valves.fourThreeWay
Shows whether the primary circuit four three way valve is active or not.
heating.scop.dhw
(DEPRECATED it will be replaced by heating.spf.dhw) Shows the SCOP for DHW.
heating.scop.heating
(DEPRECATED it will be replaced by heating.spf.heating) Shows the SCOP for heating.
heating.scop.total
(DEPRECATED it will be replaced by heating.spf.total) Shows the SCOP of heating and DHW.
heating.secondaryCircuit.operation.state
Shows information about the secondary source's supply-temperature of a heatpump.
heating.secondaryCircuit.sensors.temperature.supply
heating.secondaryCircuit.temperature.return.minimum
Shows the minimal return temperature of the secondary circuit.
heating.secondaryCircuit.transition.state
Shows the last and current transition state of the refrigeration circuit.
heating.secondaryCircuit.valves.fourThreeWay
Shows the secondary circuit Four Three Way valve state.
heating.secondaryHeatGenerator
Shows if the device is configured with a secondary heat generator.
heating.secondaryHeatGenerator.active
Shows the secondary heat generator state.
heating.secondaryHeatGenerator.configuration.defrosting
Shows if the secondary heat generator is able to support defrosting. Also provides the command to set it
heating.secondaryHeatGenerator.configuration.dhw
Shows if the secondary heat generator is able to support dhw. Also provides the command to set it.
heating.secondaryHeatGenerator.configuration.dhw.comfortEnsuring
Shows if the secondary heat generator is able to support dhw comfort ensuring mode. Also provides the command to set it
heating.secondaryHeatGenerator.configuration.frostprotection
Shows if the secondary heat generator is able to support frost protection. Also provides the command to set it
heating.secondaryHeatGenerator.configuration.heating
Shows if the secondary heat generator is able to support heating. Also provides the command to set it.
heating.secondaryHeatGenerator.configuration.heating.comfortEnsuring
Shows if the secondary heat generator is able to support heating comfort ensuring mode. Also provides the command to set it
heating.secondaryHeatGenerator.configuration.hygiene
Shows if the secondary heat generator is able to support hygiene mode. Also provides the command to set it.
heating.secondaryHeatGenerator.configuration.parallelWorking
Shows the second heat generator parallel work capability. Provides commands to it.
heating.secondaryHeatGenerator.configuration.refrigerationCircuitExceeded
Shows if the secondary heat generator is able to support additional heater if the application limits of the refrigeration circuit have been exceeded. Also provides the command to set it
heating.secondaryHeatGenerator.configuration.runtime
Shows the second heat generator's minimal runtime, minimal break time, and delay time. Provide commands to configure them.
heating.secondaryHeatGenerator.configuration.screedDrying
Shows if the secondary heat generator is able to support screed drying. Also provides the command to set it
heating.secondaryHeatGenerator.configuration.temperature
Shows the first device allowed temperature difference between target and current values without starting the second heat generator. Provides commands to configure them.
heating.secondaryHeatGenerator.electricity.energyFactor
Shows the secondary heat generator configured electricity energy factor for ecological calculation. Provides a command to set it.
heating.secondaryHeatGenerator.electricity.price.low
Shows the configured minimum tariff price for electricity per kilowatt-hour for economical calculation. Provides a command to set it.
heating.secondaryHeatGenerator.electricity.price.normal
Shows the configured normal tariff price for electricity per kilowatt-hour for economical calculation. Provides a command to set it.
heating.secondaryHeatGenerator.fossil.energyFactor
Shows the configured fossil energy factor for ecological calculation. Provides a command to set it.
heating.secondaryHeatGenerator.fossil.price.normal
Shows the configured normal tariff price for fossil per kilowatt-hour for economical calculation. Provides a command to set it.
heating.secondaryHeatGenerator.state
Shows the current state of the secondary heat generator.
heating.secondaryHeatGenerator.status
Shows the status of a second heat generator.
heating.secondaryHeatGenerator.temperature.current
Shows the current temperature of a second heat generator
heating.secondaryHeatGenerator.valves.threeWay
Shows the current and target position of the three-way valve in the secondary heat generator.
heating.sensors.pressure.hotGas
(DEPRECATED it will be replaced by heating.compressors.N.sensors.pressure.outlet) Shows information about the value and the status of the suction pressure sensor.
heating.sensors.pressure.suctionGas
(DEPRECATED it will be replaced by heating.compressors.N.sensors.pressure.inlet) Shows information about the value and the status of the suction pressure sensor.
heating.sensors.pressure.supply
Shows the water-pressure in the boiler's supply.
heating.sensors.temperature.allengra
Shows the return temperature of allengra
heating.sensors.temperature.hotGas
(DEPRECATED it will be replaced by heating.compressors.N.sensors.temperature.outlet) Shows information about the value and the status of the hotgas temperature sensor.
heating.sensors.temperature.hydraulicSeparator
heating.sensors.temperature.increasedReturn
Shows information about Return set Temperature of the interim system e.g. Temperature behind a built-in buffer when a system is supported with a return increase.
heating.sensors.temperature.liquidGas
(DEPRECATED it will be replaced by heating.evaporators.N.sensors.temperature.liquid) Shows information about the value and the status of the suctiongas temperature sensor.
heating.sensors.temperature.outside
Shows information related to outside temperature sensor.
heating.sensors.temperature.return
heating.sensors.temperature.suctionGas
(DEPRECATED it will be replaced by heating.compressors.N.sensors.temperature.inlet) Shows information about the value and the status of the suctiongas temperature sensor.
heating.sensors.temperature.systemReturn
Shows information about (Common return temperature) return sum of temperature of a cascade.
Heating+
heating.sensors.valve.bufferDischargeThreeWayValve
Shows information about percentage position of the buffer discharge 3-way valve.
heating.sensors.valve.N.expansion.setpoint
Shows the valve expansion setpoint in percent.
heating.sensors.valve.N.expansion.target
Shows the valve target expansion in percent.
heating.sensors.volumetricFlow.allengra
Shows information about volumetric flow on the return.
heating.solar
Shows status of solar
heating.solar.power.cumulativeProduced
Shows of solar heat quantity in kWh
heating.solar.power.production
Shows statistics of solar power production
heating.solar.pumps.circuit
heating.solar.rechargeSuppression
Shows the status of recharge suppression.
heating.solar.sensors.temperature.collector
Shows Solar Collector temperature in °C
heating.solar.sensors.temperature.dhw
Shows solar dhw temperature in °C
Heating+
heating.solar.statistics
Shows statistics of solar operating hours.
heating.solar.status
heating.solar.summary.power.production
Shows cumulated statistics of generated heat energy for the space climate heating.
Heat pump
heating.spf.dhw
Shows the SPF for DHW.
Heat pump
heating.spf.heating
Shows the SPF for heating.
Heat pump
heating.spf.total
Shows the SPF of heating and DHW.
heating.suctionModule.statistics
Shows statistics of suction module operating hours.
heating.temperature.commonSupply
Shows the value and unit of common flow temperature setpoint. Also includes the command to change the common flow temperature setpoint
heating.valves.fourThreeWay.position
Shows the current position of the Four Three Way valve.
heating.venting.available
Shows a device venting availability.
Photovoltaic
photovoltaic.installedPeakPower
Shows the total installed power of the photovoltaic system.
DevPortalPhotovoltaicRead, Photovoltaic, DevPortalEuDataActRead
photovoltaic.production.cumulated
Shows the produced energy of the photovoltaic system in different periods.
photovoltaic.production.cumulated.consolidated
Shows the consolidated energy values from photovoltaic panels in cascade.
photovoltaic.production.current
Shows the power which the photovoltaic panel affords in watt.
photovoltaic.status
Shows the status of photovoltaic system.
photovoltaic.string
Shows information about enabled strings.
photovoltaic.string.current
Shows the current power of the first, second and the third photovoltaic string in ampere.
photovoltaic.string.N.electricity
Shows electricity of the photovoltaic strings.
photovoltaic.string.N.power
Shows current power of the photovoltaic strings.
photovoltaic.string.N.voltage
Shows voltage of the photovoltaic strings.
photovoltaic.string.voltage
Shows the voltage value for the first, second and the third photovoltaic string in volt.
Point of common coupling (PCC)
pcc.ac.active.current
Shows the current active power for each phase and for all together in ampere.
pcc.ac.active.power
Shows the active power at the common point of coupling.
pcc.ac.reactive.power
Shows the reactive power at the common point of coupling.
pcc.state.gridCode
Shows the grid code settings.
pcc.transfer.consumption.total
Shows the value of total consumption over the point of coupling.
pcc.transfer.feedIn.total
Shows the total feed in of the point of coupling.
pcc.transfer.power.exchange
Shows the value power of exchange.
Rooms
rooms.features.remotePresenceProbability
Shows wether remotePresenceProbability is currently activated for supply channel N.
rooms.features.supplyChannel0FTDC
Shows the FTDC for supply channel N state. Provides command to it.
rooms.features.supplyChannel0FTDCUseValveInformation
Shows the FTDC valve information usage for supply channel N. Provides command to it.
rooms.features.supplyChannel0PumpControl
Shows the Pump Control usage for supply channel N. Provides command to it.
rooms.N.algorithm
Provides a command to set its configuration.
rooms.N.childLock
Shows the 'Child-lock' function on the eTRV activation for the room. Provides commands to it.
rooms.N.co2
Shows the desired CO2 concentration.
rooms.N.condensationRisk
Shows the condensation risk of the room.
rooms.N.configuration.heatOnTime
Shows whether heat on time algorithm is active for the room. Provides the command to activate or deactivate it.
rooms.N.configuration.hydraulicBalancing
Shows whether the automatic hydraulic balancing is turned on or off.
rooms.N.configuration.openWindow
Shows the 'Open window' function activation for the room. Provides commands to it.
rooms.N.configuration.trvAlgorithmActive
Shows the TRV algorithm activation for the room. Provide a command to set it.
rooms.N.configuration.window.openState
rooms.N.operating.programs.comfort
Shows the 'Comfort' operating program activation and its desired temperature for the room. Provides a command to set the temperature.
SRC
rooms.N.operating.programs.comfortCooling
Shows the 'Comfort cooling' operating program activation and its desired temperature for the room. Provides a command to set the temperature.
SRC
rooms.N.operating.programs.comfortHeating
Shows the 'Comfort heating' operating program activation and its desired temperature for the room. Provides a command to set the temperature.
SRC
rooms.N.operating.programs.normalCooling
Shows the 'Normal cooling' operating program activation and its desired temperature for the room. Provides a command to set the temperature.
SRC
rooms.N.operating.programs.normalHeating
Shows information about normal program of the room
SRC
rooms.N.operating.programs.reducedCooling
Shows the 'Reduced cooling' operating program activation and its desired temperature for the room. Provides a command to set the temperature.
SRC
rooms.N.operating.programs.reducedHeating
Shows information about reduced program of the room
SRC
rooms.N.operating.state
Shows information about the current state of the room.
SRC
rooms.N.quickmodes.manual
Shows the 'Manual' quick mode activation and its configuration for the room. Provides commands to it and set the temperature.
SRC
rooms.N.quickmodes.manualTillNextSchedule
SRC
rooms.N.schedule
Shows heating schedule for room N and provides command to set a new one.
SRC
rooms.N.sensors.co2
Shows the sensor status, a weighted average of all measured co2-values in the room. The value is mapped into a level according to the provided legend.
SRC, DevPortalEuDataActRead
rooms.N.sensors.humidity
Shows the weighted average of all humidity sensor values measured in the room.
rooms.N.sensors.openWindow
Shows the open window detection in the room.
rooms.N.sensors.temperature
rooms.N.sensors.window.openState
rooms.N.temperature.levels.comfort.cooling
Shows the calculated comfort level cooling temperature in the room.
rooms.N.temperature.levels.comfort.heating
Shows the calculated comfort level heating temperature in the room.
rooms.N.temperature.levels.comfort.perceived
Shows the desired comfort level temperature in the room. Provides a command to set it.
rooms.N.temperature.levels.cooling
Shows the effective set point temperature for cooling in the room.
rooms.N.temperature.levels.heating
Shows the effective set point temperature for heating in the room.
rooms.N.temperature.levels.normal.cooling
Shows the calculated normal level cooling temperature in the room.
rooms.N.temperature.levels.normal.heating
Shows the calculated normal level heating temperature in the room.
rooms.N.temperature.levels.normal.perceived
Shows the desired normal level temperature in the room. Provides a command to set it.
rooms.N.temperature.levels.reduced.cooling
Shows the calculated reduced level cooling temperature in the room.
rooms.N.temperature.levels.reduced.heating
Shows the calculated reduced level heating temperature in the room.
rooms.N.temperature.reference
Provides a command to set the reference temperature in the room used to calibrate the algorithms.
SRC
rooms.others
Shows other rooms available for the device.
rooms.others.N.algorithm
rooms.others.N.condensationRisk
rooms.others.N.operating.programs.comfort
Shows the 'Comfort' operating program activation and its desired temperature for the other room. Provides a command to set the temperature.
rooms.others.N.sensors.humidity
Shows the weighted average of all humidity sensor values measured in the other room.
rooms.others.N.sensors.temperature
Shows the weighted average of all temperature sensor values measured in the other room.
rooms.others.N.temperature.levels.comfort.cooling
Shows the calculated comfort level cooling temperature in the other room.
rooms.others.N.temperature.levels.comfort.heating
Shows the calculated comfort level heating temperature in the other room.
rooms.others.N.temperature.levels.comfort.perceived
Shows the desired comfort level temperature in the other room. Provides a command to set it.
rooms.others.N.temperature.levels.cooling
Shows the effective set point temperature for cooling in the other room.
rooms.others.N.temperature.levels.heating
Shows the effective set point temperature for heating in the other room.
rooms.others.N.temperature.levels.normal.cooling
Shows the calculated normal level cooling temperature in the other room.
rooms.others.N.temperature.levels.normal.heating
Shows the calculated normal level heating temperature in the other room.
rooms.others.N.temperature.levels.normal.perceived
Shows the desired normal level temperature in the other room. Provides a command to set it.
rooms.others.N.temperature.levels.reduced.cooling
Shows the calculated reduced level cooling temperature in the other room.
rooms.others.N.temperature.levels.reduced.heating
Shows the calculated reduced level heating temperature in the other room.
rooms.remotePresenceProbability
Shows the probability that the user (and connected persons) are away from geofencing-perspective.
SRC
rooms.status
Shows information about rooms status
tcu
tcu.ethernet.N.config
Shows configuration of LAN interface N.
tcu.features.hems
Shows whether hems is currently activated. Also provides command to de/activate it.
tcu.features.wirelessRemoteController
Shows the device Wireless Remote Controller connectivity possibility. Provides command to de/-activate it.
DevPortalHeatingRead, Heating
tcu.wifi
Shows information related to the WiFi in a tcu.
tcu.wifi.accessPoint
Closes the access point of the gateway.
Thermostatic radiator valve (TRV)
trv.childLock
Shows the eTRV 'Child-lock' function activation.
trv.mountingMode
Shows the eTRV mounting mode activation.
trv.temperature
Shows the target temperature of the eTRV. Provides a command to set it.
trv.valve.position
Shows the eTRV valve position.
vcs
vcs.session
Shows the status of the Wallbox Session.
vcs.session.charging
Shows the charged energy and the duration of the session.
Ventilation
ventilation.air.balance.offset
Shows the inflow and the output flow of the air in percent. Depends on ventilation.air.balance.volumeFlow whether 10% will be added or subtracted.
ventilation.airQuality.co
Shows the current calculated value of carbon monoxide and the sensor connection status in the ventilation system.
ventilation.airQuality.co2
Shows the current calculated value of carbon dioxide and the sensor connection status in the ventilation system.
ventilation.airQuality.organicComponents
Shows the current calculated value of organic components and the sensor connection status in the ventilation system.
ventilation.airQuality.pm10
Shows the current calculated value of dust and the sensor connection status in the ventilation system.
ventilation.airQuality.pm2d5
Shows the current calculated value of fine dust and the sensor connection status in the ventilation system.
ventilation.airQuality.temperature
Shows the current calculated value of temperature and the sensor connection status in the ventilation system.
ventilation.bypass
Shows whether the bypass is available or not.
ventilation.bypass.configuration.temperature.perceived
Shows the perceived temperature for bypass mode. Also provides command to set it.
ventilation.bypass.configuration.temperature.supply.dynamicRegulation
Shows supply temperature for bypass operating mode automatic automatic regulation. Also provides command to set it.
ventilation.bypass.configuration.temperature.supply.smoothRegulation
ventilation.bypass.operating.modes.active
Shows which operating mode is active on the bypass.
ventilation.bypass.operating.modes.automatic
ventilation.bypass.operating.modes.open
Shows whether the bypass operating mode open is active or not.
ventilation.bypass.position
Shows the position of the bypass in percent.
ventilation.control.filterChange
Control filter Change.
ventilation.external.lock
Shows whether the external lock for the ventilation system is active or not.
ventilation.fan.assignmentSwitch
Shows if the fan assignment switch is active.
ventilation.fan.exhaust
Shows the current and target fan RPM of exhaust ventilation.
ventilation.fan.exhaust.runtime
Shows the runtime of the exhaust fan in the ventilation system in the ventilation system.
ventilation.fan.supply
Shows the current and target fan RPM of supply ventilation.
ventilation.fan.supply.runtime
Shows the runtime of the supply fan.
ventilation.features.co
Shows whether the CO is currently activated
ventilation.features.co2
Shows whether the CO2 is currently activated
ventilation.features.dust
Shows whether the Dust is currently activated
ventilation.features.finedust
Shows whether the FineDust is currently activated
ventilation.features.organicComponent
Shows whether the OrganicComponent is currently activated
ventilation.filter.information
Shows the filter-related information.
ventilation.filter.pollution.blocked
Shows the percentage blocked of the pollution filter
ventilation.filter.runtime
Shows how much hours the ventilation system worked with this filter.
ventilation.heatExchanger.frostprotection
Shows whether the frostprotection for the heat exchanger is active or not.
ventilation.heatExchanger.frostprotection.operating.modes.disbalance
Shows if the "Disbalance" frost protection operating mode is active for the device.
ventilation.heatExchanger.frostprotection.operating.modes.intermittent
Shows if the "Intermittent" frost protection operating mode is active for the device.
ventilation.heatExchanger.frostprotection.operating.modes.preheater
Shows if the "Preheater" frost protection operating mode is active for the device.
ventilation.heatExchanger.frostprotection.operating.modes.preheatereco
Shows if the "Preheater Eco Mode" frost protection operating mode is active and its limits for the device.
ventilation.heating.recovery
Shows the heat recovery in percent.
ventilation.levels.levelFour
Shows whether ventilation operating program is active with maximal air volume flow.
ventilation.levels.levelOne
Shows whether ventilation operating program is active with minimum air flow.
ventilation.levels.levelThree
Shows whether ventilation operating program is active with standard air volume flow.
ventilation.levels.levelTwo
Shows whether ventilation operating program is active with reduced air volume flow.
ventilation.lockExternal
Shows ventilation external lock function settings.
ventilation.operating.modes.active
Shows current active operating mode enabled on the device.
DevPortalHeatingRead, Heating, DevPortalEuDataActRead
ventilation.operating.modes.filterChange
Shows whether the filter change mode is active or not.
ventilation.operating.modes.permanent
Shows whether the ventilation operating mode permanent is active or not.
ventilation.operating.modes.sensorDriven
Shows whether the ventilation operating mode driven by sensors is active or not.
ventilation.operating.modes.sensorOverride
Shows whether the ventilation operating mode sensorOverride is active or not and the current behavior.
ventilation.operating.modes.standard
Shows whether Standard operating mode is active with minimum air flow.
ventilation.operating.modes.standby
Shows whether Standby operating mode is active.
ventilation.operating.modes.ventilation
Shows whether Ventilation operating mode is active.
ventilation.operating.programs.active
ventilation.operating.state
Shows information about the current state of the ventilation.
ventilation.preHeater
Shows the electrical pre-heater activation in the ventilation system.
ventilation.preHeater.power.consumption
Shows cumulated statistics of the preheater energy consumption in the ventilation system.
ventilation.preHeater.power.consumption.current
shows the current approximate power consumption of the electrical pre heate
ventilation.preHeater.statistics
Show the statistics of the Heater.
ventilation.quickmodes.comfort
Shows if comfort quickmodes of ventilation is active. Also provides the commands to activate/deactivate it.
ventilation.quickmodes.eco
Shows if eco quickmodes of ventilation is active. Also provides the commands to activate/deactivate it.
ventilation.quickmodes.forcedLevelFour
Shows whether ventilation operating program is active with maximum air flow.
ventilation.quickmodes.holiday
Shows if holiday quickmodes of ventilation is active. Also provides the commands to changeEndDate or schedule it.
ventilation.quickmodes.silent
Shows whether the silent quick mode is active and how long it is still active.
ventilation.quickmodes.standby
Shows if quickmode standby for ventilation is active. Also provides the commands to activate/deactivate it.
ventilation.quickmodes.temporaryShutdown
ventilation.schedule
Shows schedule of ventilation and provides command to set a new one.
ventilation.sensors.actuator.selftest
Shows sensors actuator self-test activation and status.
ventilation.sensors.airBorneDust.pm1
Shows the status and value of the sensor.
ventilation.sensors.airBorneDust.pm10
Shows information related to Ventilation exhaust temperature sensor.
ventilation.sensors.airBorneDust.pm2d5
ventilation.sensors.airBorneDust.pm4
ventilation.sensors.airQuality
Shows the air quality and the status of the air quality sensor.
ventilation.sensors.humidity.exhaust
shows the sensor value for exhaust humidity and its status
ventilation.sensors.humidity.extract
shows the sensor value for extract humidity and its status
ventilation.sensors.humidity.outdoor
shows the sensor value for outdoor humidity and its status
ventilation.sensors.humidity.supply
shows the sensor value for supply humidity and its status
ventilation.sensors.temperature.exhaust
ventilation.sensors.temperature.extract
Shows information related to Ventilation extract temperature sensor.
ventilation.sensors.temperature.outside
Shows the outside temperature value in the ventilation system.
ventilation.sensors.temperature.supply
Shows the supplied temperature value in the ventilation system.
ventilation.sensors.volatileOrganicCompounds
ventilation.switchActivation
Shows external switch activation for quick selection.
ventilation.volumeFlow.current.input
Shows the input air volume flow.
ventilation.volumeFlow.current.output
Shows the output air volume flow.
water
water.consumption.flow.current
Shows the current flow of water
water.consumption.flow.max
Shows the maximum recorded flow of water
water.consumption.summary
Shows cumulated statistics of consumed water
water.leakDetection.configuration.flowAlert
The current flow of consumed water.
water.leakDetection.sensors.leakage.N.battery
Shows the battery level in percent.
water.leakDetection.sensors.leakage.N.id
Shows the sensor's MAC address.
water.leakDetection.sensors.leakage.N.name
Shows the name of the sensor and allows to change it.
water.leakDetection.sensors.leakage.N.rssi
Shows the Received signal strength indication.
water.leakDetection.sensors.leakage.N.version.hardware
Shows the hardware-version of the sensor.
water.leakDetection.sensors.leakage.N.version.software
Shows the software-version of the sensor.
water.softener.configuration.lowSaltAlert
Allows setting the minimum days of salt stock. If the stock does not last for this number of days, an alert will be raised.
water.softener.salt.level.days
Shows for how many days the salt in stock will last.
water.valves.shutoff.holiday
Shows weather the holiday-program is currently active.
water.valves.shutoff.motor
Shows the current state of the shutoff-valve's motor.
water.valves.shutoff.position
Shows the current position of the shutoff-valve.
