2023-11-23 00:39:22.738 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% set curHour = now().hour | string %}
{{ state_attr("sensor.porssari_json_data", "Channel1")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.739 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{{ state_attr("sensor.porssari_json_data", "Channel2")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.740 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{{ state_attr("sensor.porssari_json_data", "Channel3")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.741 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{{ state_attr("sensor.porssari_json_data", "Channel4")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
{{ state_attr("sensor.porssari_json_data", "Channel5")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.744 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{{ state_attr("sensor.porssari_json_data", "Channel6")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.745 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{{ state_attr("sensor.porssari_json_data", "Channel7")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.746 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{{ state_attr("sensor.porssari_json_data", "Channel8")[curHour] }}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.751 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.752 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.753 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% else %}
{{ -1 }}
{% endif %}'
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.754 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.758 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% else %}
{{ -1 }}
{% endif %}'
2023-11-23 00:39:22.759 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.helpers.template.Wrapper object' has no attribute '0' when rendering '{% if is_state('binary_sensor.porssari_json_controls', 'on') %}
{% else %}
{{ -1 }}
{% endif %}'
{% else %}
{{ -1 }}
{% endif %}'
