| * Contains code from: |
| * http://randomnerdtutorials.com/esp8266-remote-controlled-sockets/ |
| * http://www.bruhautomation.com/p/cheapest-wifi-automated-blinds.html |
| * https://www.arduino.cc/en/Tutorial/Sweep |
| * Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except |
| * in compliance with the License. You may obtain a copy of the License at: |
| * http://www.apache.org/licenses/LICENSE-2.0 |
| * Unless required by applicable law or agreed to in writing, software distributed under the License is distributed |
| * on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License |
| * for the specific language governing permissions and limitations under the License. |
| #include <ESP8266WiFi.h> |
| #include <WiFiClient.h> |
| #include <ESP8266WebServer.h> |
| #include <ESP8266mDNS.h> |
| #include <Servo.h> |
| #define WLAN_SSID "YOUR WIFI SSID" //change to your Wifi SSID |
| #define WLAN_PASS "YOUR WIFI PASSWORD" //change to your Wifi Password |
| MDNSResponder mdns; |
| ESP8266WebServer server(80); |
| int servoPin = 0; //Servo on GPIO0 or NODEMCU pin D3 |
| const int buttonPin = 12; //manual button on GPIO12 or NODEMCU pin D6 |
| int buttonState = 0; |
| int direction = 0; |
| int setting = 0; //Startup with blinds closed |
| int position = 90; |
| Servo servoA; |
| String webPage = ""; |
| void setup(void) { |
| WiFi.mode(WIFI_STA); |
| webPage += "<h1>ESP8266 Web Server</h1><p>Blinds<br>"; |
| webPage += "<a href=\"0\"><button>0</button></a><br>"; |
| webPage += "<a href=\"10\"><button>10</button></a><br>"; |
| webPage += "<a href=\"20\"><button>20</button></a><br>"; |
| webPage += "<a href=\"30\"><button>30</button></a><br>"; |
| webPage += "<a href=\"40\"><button>40</button></a><br>"; |
| webPage += "<a href=\"50\"><button>50</button></a><br>"; |
| webPage += "<a href=\"60\"><button>60</button></a><br>"; |
| webPage += "<a href=\"70\"><button>70</button></a><br>"; |
| webPage += "<a href=\"80\"><button>80</button></a><br>"; |
| webPage += "<a href=\"90\"><button>90</button></a><br>"; |
| webPage += "<a href=\"100\"><button>100</button></a><br>"; |
| delay(1000); |
| pinMode(buttonPin, INPUT_PULLUP); |
| Serial.begin(9600); |
| delay(500); |
| Serial.println("Blind Startup Sequence"); |
| delay(500); |
| Serial.println(); |
| Serial.print("Connecting to "); |
| Serial.println(WLAN_SSID); |
| WiFi.begin(WLAN_SSID, WLAN_PASS); |
| // Set a static IP (optional) |
| //IPAddress ip(10,0,1,50); |
| //IPAddress gateway(10,0,1,1); |
| //IPAddress subnet(255, 255, 255, 0); |
| //WiFi.config(ip, gateway, subnet); |
| // End of set a static IP (optional) |
| delay(500); |
| int i = 0; |
| while (WiFi.status() != WL_CONNECTED) { |
| delay(500); |
| Serial.print("."); |
| ESP.wdtFeed(); |
| if (i > 40) // Try 40 times to connect to Wifi |
| Serial.print("Restarting Wifi"); ESP.reset(); // Reset Wifi stack if more than 40 trys |
| i++; |
| // Set a static IP retry (optional) |
| // End of set a static IP retry (optional) |
| Serial.println(); |
| Serial.println("WiFi connected"); |
| Serial.println("IP address: "); Serial.println(WiFi.localIP()); |
| if (mdns.begin("esp8266", WiFi.localIP())) { |
| Serial.println("MDNS responder started"); |
| server.on("/", []() { server.send(200, "text/html", webPage); }); |
| server.on("/100", []() { server.send(200, "text/html", webPage); setting = 180; }); |
| server.on("/99", []() { server.send(200, "text/html", webPage); setting = 180; }); |
| server.on("/98", []() { server.send(200, "text/html", webPage); setting = 180; }); |
| server.on("/97", []() { server.send(200, "text/html", webPage); setting = 171; }); |
| server.on("/96", []() { server.send(200, "text/html", webPage); setting = 171; }); |
| server.on("/95", []() { server.send(200, "text/html", webPage); setting = 171; }); |
| server.on("/94", []() { server.send(200, "text/html", webPage); setting = 171; }); |
| server.on("/93", []() { server.send(200, "text/html", webPage); setting = 171; }); |
| server.on("/92", []() { server.send(200, "text/html", webPage); setting = 162; }); |
| server.on("/91", []() { server.send(200, "text/html", webPage); setting = 162; }); |
| server.on("/90", []() { server.send(200, "text/html", webPage); setting = 162; }); |
| server.on("/89", []() { server.send(200, "text/html", webPage); setting = 162; }); |
| server.on("/88", []() { server.send(200, "text/html", webPage); setting = 162; }); |
| server.on("/87", []() { server.send(200, "text/html", webPage); setting = 153; }); |
| server.on("/86", []() { server.send(200, "text/html", webPage); setting = 153; }); |
| server.on("/85", []() { server.send(200, "text/html", webPage); setting = 153; }); |
| server.on("/84", []() { server.send(200, "text/html", webPage); setting = 153; }); |
| server.on("/83", []() { server.send(200, "text/html", webPage); setting = 153; }); |
| server.on("/82", []() { server.send(200, "text/html", webPage); setting = 144; }); |
| server.on("/81", []() { server.send(200, "text/html", webPage); setting = 144; }); |
| server.on("/80", []() { server.send(200, "text/html", webPage); setting = 144; }); |
| server.on("/79", []() { server.send(200, "text/html", webPage); setting = 144; }); |
| server.on("/78", []() { server.send(200, "text/html", webPage); setting = 144; }); |
| server.on("/77", []() { server.send(200, "text/html", webPage); setting = 135; }); |
| server.on("/76", []() { server.send(200, "text/html", webPage); setting = 135; }); |
| server.on("/75", []() { server.send(200, "text/html", webPage); setting = 135; }); |
| server.on("/74", []() { server.send(200, "text/html", webPage); setting = 135; }); |
| server.on("/73", []() { server.send(200, "text/html", webPage); setting = 135; }); |
| server.on("/72", []() { server.send(200, "text/html", webPage); setting = 126; }); |
| server.on("/71", []() { server.send(200, "text/html", webPage); setting = 126; }); |
| server.on("/70", []() { server.send(200, "text/html", webPage); setting = 126; }); |
| server.on("/69", []() { server.send(200, "text/html", webPage); setting = 126; }); |
| server.on("/68", []() { server.send(200, "text/html", webPage); setting = 126; }); |
| server.on("/67", []() { server.send(200, "text/html", webPage); setting = 117; }); |
| server.on("/66", []() { server.send(200, "text/html", webPage); setting = 117; }); |
| server.on("/65", []() { server.send(200, "text/html", webPage); setting = 117; }); |
| server.on("/64", []() { server.send(200, "text/html", webPage); setting = 117; }); |
| server.on("/63", []() { server.send(200, "text/html", webPage); setting = 117; }); |
| server.on("/62", []() { server.send(200, "text/html", webPage); setting = 108; }); |
| server.on("/61", []() { server.send(200, "text/html", webPage); setting = 108; }); |
| server.on("/60", []() { server.send(200, "text/html", webPage); setting = 108; }); |
| server.on("/59", []() { server.send(200, "text/html", webPage); setting = 108; }); |
| server.on("/58", []() { server.send(200, "text/html", webPage); setting = 108; }); |
| server.on("/57", []() { server.send(200, "text/html", webPage); setting = 99; }); |
| server.on("/56", []() { server.send(200, "text/html", webPage); setting = 99; }); |
| server.on("/55", []() { server.send(200, "text/html", webPage); setting = 99; }); |
| server.on("/54", []() { server.send(200, "text/html", webPage); setting = 99; }); |
| server.on("/53", []() { server.send(200, "text/html", webPage); setting = 99; }); |
| server.on("/52", []() { server.send(200, "text/html", webPage); setting = 90; }); |
| server.on("/51", []() { server.send(200, "text/html", webPage); setting = 90; }); |
| server.on("/50", []() { server.send(200, "text/html", webPage); setting = 90; }); |
| server.on("/49", []() { server.send(200, "text/html", webPage); setting = 90; }); |
| server.on("/48", []() { server.send(200, "text/html", webPage); setting = 90; }); |
| server.on("/47", []() { server.send(200, "text/html", webPage); setting = 81; }); |
| server.on("/46", []() { server.send(200, "text/html", webPage); setting = 81; }); |
| server.on("/45", []() { server.send(200, "text/html", webPage); setting = 81; }); |
| server.on("/44", []() { server.send(200, "text/html", webPage); setting = 81; }); |
| server.on("/43", []() { server.send(200, "text/html", webPage); setting = 81; }); |
| server.on("/42", []() { server.send(200, "text/html", webPage); setting = 72; }); |
| server.on("/41", []() { server.send(200, "text/html", webPage); setting = 72; }); |
| server.on("/40", []() { server.send(200, "text/html", webPage); setting = 72; }); |
| server.on("/39", []() { server.send(200, "text/html", webPage); setting = 72; }); |
| server.on("/38", []() { server.send(200, "text/html", webPage); setting = 72; }); |
| server.on("/37", []() { server.send(200, "text/html", webPage); setting = 63; }); |
| server.on("/36", []() { server.send(200, "text/html", webPage); setting = 63; }); |
| server.on("/35", []() { server.send(200, "text/html", webPage); setting = 63; }); |
| server.on("/34", []() { server.send(200, "text/html", webPage); setting = 63; }); |
| server.on("/33", []() { server.send(200, "text/html", webPage); setting = 63; }); |
| server.on("/32", []() { server.send(200, "text/html", webPage); setting = 54; }); |
| server.on("/31", []() { server.send(200, "text/html", webPage); setting = 54; }); |
| server.on("/30", []() { server.send(200, "text/html", webPage); setting = 54; }); |
| server.on("/29", []() { server.send(200, "text/html", webPage); setting = 54; }); |
| server.on("/28", []() { server.send(200, "text/html", webPage); setting = 54; }); |
| server.on("/27", []() { server.send(200, "text/html", webPage); setting = 45; }); |
| server.on("/26", []() { server.send(200, "text/html", webPage); setting = 45; }); |
| server.on("/25", []() { server.send(200, "text/html", webPage); setting = 45; }); |
| server.on("/24", []() { server.send(200, "text/html", webPage); setting = 45; }); |
| server.on("/23", []() { server.send(200, "text/html", webPage); setting = 45; }); |
| server.on("/22", []() { server.send(200, "text/html", webPage); setting = 36; }); |
| server.on("/21", []() { server.send(200, "text/html", webPage); setting = 36; }); |
| server.on("/20", []() { server.send(200, "text/html", webPage); setting = 36; }); |
| server.on("/19", []() { server.send(200, "text/html", webPage); setting = 36; }); |
| server.on("/18", []() { server.send(200, "text/html", webPage); setting = 36; }); |
| server.on("/17", []() { server.send(200, "text/html", webPage); setting = 27; }); |
| server.on("/16", []() { server.send(200, "text/html", webPage); setting = 27; }); |
| server.on("/15", []() { server.send(200, "text/html", webPage); setting = 27; }); |
| server.on("/14", []() { server.send(200, "text/html", webPage); setting = 27; }); |
| server.on("/13", []() { server.send(200, "text/html", webPage); setting = 27; }); |
| server.on("/12", []() { server.send(200, "text/html", webPage); setting = 18; }); |
| server.on("/11", []() { server.send(200, "text/html", webPage); setting = 18; }); |
| server.on("/10", []() { server.send(200, "text/html", webPage); setting = 18; }); |
| server.on("/9", []() { server.send(200, "text/html", webPage); setting = 18; }); |
| server.on("/8", []() { server.send(200, "text/html", webPage); setting = 18; }); |
| server.on("/7", []() { server.send(200, "text/html", webPage); setting = 9; }); |
| server.on("/6", []() { server.send(200, "text/html", webPage); setting = 9; }); |
| server.on("/5", []() { server.send(200, "text/html", webPage); setting = 9; }); |
| server.on("/4", []() { server.send(200, "text/html", webPage); setting = 9; }); |
| server.on("/3", []() { server.send(200, "text/html", webPage); setting = 9; }); |
| server.on("/2", []() { server.send(200, "text/html", webPage); setting = 0; }); |
| server.on("/1", []() { server.send(200, "text/html", webPage); setting = 0; }); |
| server.on("/0", []() { server.send(200, "text/html", webPage); setting = 0; }); |
| server.begin(); |
| Serial.println("HTTP server started"); |
| void loop() { |
| buttonState = digitalRead(buttonPin); |
| if(buttonState == LOW && setting <= 180 && direction == 0){ |
| setting++; |
| delay(0); |
| if(setting == 180){ |
| direction = 1; |
| if(buttonState == LOW && setting >= 0 && direction == 1){ |
| setting--; |
| delay(0); |
| if(setting == 0){ |
| direction = 0; |
| if(position < setting){ |
| servoA.attach(servoPin); |
| servoA.write(position++); |
| delay(5); |
| Serial.print("Setting: "); |
| Serial.println(setting); |
| Serial.print("Position: "); |
| Serial.println(position); |
| if(position > setting){ |
| servoA.write(position--); |
| delay(5); |
| if(position == setting){ |
| servoA.detach(); |
| server.handleClient(); |
