30.08.2014 23:08:30: OUMANEH800: Received measures data: 'measures?Ulkol\xc3\xa4mp\xc3\xb6tila,S_227_85,1;L1 Menoveden l\xc3\xa4mp\xc3\xb6tila,S_259_85,1;L1 Huonel\xc3\xa4mp\xc3\xb6tila,S_2
61_85,1;Paluuveden l\xc3\xa4mp\xc3\xb6tila,S_283_85,1;Poltin P\xc3\xa4\xc3\xa4ll\xc3\xa4,S_347_85,1;Poltinh\xc3\xa4lytys,S_240_85,3;L1 Venttiilin asento,S_272_85,2;\x00'
30.08.2014 23:08:30: OUMANEH800: Retrieving Ouman EH800 data values from URL: http://192.168.16.9/request?S_259_85;S_261_85;S_240_85;S_283_85;S_347_85;S_227_85;S_272_85;
30.08.2014 23:08:30: OUMANEH800: Received data value data: 'request?S_259_85=25.5;S_261_85=23.6;S_240_85=OFF;S_283_85=25.3;S_347_85=11.9;S_227_85=4.7;S_272_85=0;\x00'
30.08.2014 23:08:30: SHELL1: Received shell command data: '23:08:30 up 6 days, 5:58, 2 users, load average: 0.41, 0.27, 0.18'
30.08.2014 23:08:30: TaloLoggerThread: Storing logged data with 8 points.
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 2, 25.5)
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 1, 4.9)
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 3, 0)
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 6, 25.3)
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 7, 23.7)
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 9, 50.7)
30.08.2014 23:08:30: MYSQLDB: Inserting data to database using SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 8, OFF)
30.08.2014 23:08:30: MYSQLDB: ERROR: Error in database operation, SQL: INSERT INTO talo_data (time, position_id, value) VALUES (FROM_UNIXTIME(1409428380), 8, OFF)
