Traceback (most recent call last):
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 684, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: 'unknown'
During handling of the above exception, another exception occurred:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 687, in state
numerical_value = float(value)
ValueError: could not convert string to float: 'unknown'
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 360, in _async_dispatch_entity_id_event
hass.async_run_hass_job(job, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 918, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1319, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 357, in _handle_results
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1024, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1149, in _async_write_ha_state
self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1086, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1030, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 691, in state
raise ValueError(
...<5 lines>...
) from err
ValueError: Sensor sensor.daikin_ml_learned_demand has device class 'None', state class 'None' unit '%' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: 'unknown' (<class 'str'>)
